[postgis-users] Problem in using Postgis 2.0.0b3 with raster
Salvatore Larosa
S_Larosa at libero.it
Thu Mar 8 01:16:23 PST 2012
check if raster2pgsql script is in folder /usr/local/pgsql/bin!
if it's there, check your path settings!
regards
----Messaggio originale----
Da: ggiakoumidakis at yahoo.com
Data: 08/03/2012 9.36
A: "postgis-users at postgis.refractions.net"<postgis-users at postgis.refractions.
net>
Ogg: [postgis-users] Problem in using Postgis 2.0.0b3 with raster
Hi, is there any step-by-step guide showing how to enable PostGis 2.0.0
beta3SVN in my database and loading raster images?
I install it properly, as the README.raster says, but when i try to load with
the "raster2pgsql -s 4326 ...." it gives "raster2pgsql command not found".
So i guess there are some missing steps after installing, that i have to do so
i can use Postgis raster to the PgAdmin database. Maybe they are so obvious to
be mentioned but i am really new to this one so i can't go further.
Thanks for any help.
