[postgis-users] ST_Overlaps and performance
Nicklas Avén nicklas.aven at jordogskog.no
Thu Mar 8 01:56:36 PST 2012
Hallo
If your query below is not the fastest of the different approaches I
think you are going into a classical trap.
It is probably notthe query that takes a long time but the output of the
result.
Find out by not returning all the resulting geometries but instaed just
count them.
Instead of using "SELECT *" use "SELSECT count(*)"
and compare the run-times.
the calculation with the && operator (the index-based bbox selecton) is
done behind the scenes when you use ST_Contains so it makes no sense
that ST_Contains should be faster in ay other way that it returns fewer
resulting polygons.
HTH
Nicklas
On Wed, 2012-03-07 at 10:30 -0800, DrYSG wrote:
> Not a great improvement in performance using:
> SELECT *
> FROM portal.metadata as cat
> WHERE cat.location && 'SRID=4326;POLYGON((-70.9433962
> 41.5384615,-72.5283019 41.5384615,-72.5283019 41.1538462,-70.9433962
> 41.1538462,-70.9433962 41.5384615))'::geometry;
> 13:27:44  [SELECT - 2862 row(s), 37.360 secs]  Result set fetched
> ... 1 statement(s) executed, 2862 row(s) affected, exec/fetch time:
> 37.360/0.073 sec  [1 successful, 0 warnings, 0 errors]
> View this message in context: http://postgis.17.n6.nabble.com/ST-Overlaps-and-performance-tp4555465p4555662.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
