[postgis-users] problem with raster2pgsql
cheryl buckley
cheryl.bckl at gmail.com
Thu Mar 8 03:07:25 PST 2012
Hi bborie and Pierre,
I am not too sure if what I did was a hundred percent correct. I was
thinking perhaps I am suppose to make a setting in QGIS to obtain a
corrected image, and not alter the "-t 100x100" in the raster2pgsql
command line, i'm not too sure. But, non-the-less find attached zip
folders (screenshots) of my images I generated. The first set is the
faulty images with the "-t 100x100" and the second set is the images
generated with a "-t 300x300". Please note that the hillshade image
in this case also came out faulty. I also made screenshots of the
histograms of the images. Perhaps this will now shed some light.
Please do confirm if you were able to unzip the images and view them.
Regards
On Thu, Mar 8, 2012 at 10:14 AM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca> wrote:
>> Yes. All tiles of a raster will have the same dimensions. So an edge tile would
>> have the same dimensions as every other tile, just that some of the tiles have no
>> data.
> Probably no link with the bug being discussed but I'm curious. What happen when the raster do not have a nodata value defined and you have to pad some tiles?
> Pierre
> postgis-users mailing list
Greetings
Cheryl
Type: application/zip
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120308/aa79bf36/attachment.zip>
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120308/aa79bf36/attachment-0001.zip>
