[postgis-users] problem with raster2pgsql
Bborie Park
bkpark at ucdavis.edu
Thu Mar 8 10:37:32 PST 2012
I just double-checked the images on QGIS 1.7.3 using the latest GDAL
trunk (r24093) with the PostGIS Raster plugin.
I've attached screenshots in QGIS.
On Thu, Mar 8, 2012 at 10:29 AM, Bborie Park <bkpark at ucdavis.edu> wrote:
> Cheryl,
> I took a look at your adjusted images and they fine by me. I loaded
> the PNG files into PostGIS Raster and ran an ST_Histogram on the
> aspect image to see if the data is there.
> I called raster2pgsql with the following...
> raster2pgsql -t 50x50 -I -C -Y Aspect.png aspect > aspect.sql
> My bet is that there is something wrong with QGIS, which uses GDAL to
> access PostGIS raster. There is another email thread related to
> PostGIS raster access using GDAL and problems arising from that.
> -bborie
> On Thu, Mar 8, 2012 at 3:07 AM, cheryl buckley <cheryl.bckl at gmail.com> wrote:
>> Hi bborie and Pierre,
>> I am not too sure if what I did was a hundred percent correct. I was
>> thinking perhaps I am suppose to make a setting in QGIS to obtain a
>> corrected image, and not alter the "-t 100x100" in the raster2pgsql
>> command line, i'm not too sure. But, non-the-less find attached zip
>> folders (screenshots) of my images I generated. The first set is the
>> faulty images with the "-t 100x100" and the second set is the images
>> generated with a "-t 300x300". Please note that the hillshade image
>> in this case also came out faulty. I also made screenshots of the
>> histograms of the images. Perhaps this will now shed some light.
>> Please do confirm if you were able to unzip the images and view them.
>> Regards
>> On Thu, Mar 8, 2012 at 10:14 AM, Pierre Racine
>> <Pierre.Racine at sbf.ulaval.ca> wrote:
>>>> Yes. All tiles of a raster will have the same dimensions. So an edge tile would
>>>> have the same dimensions as every other tile, just that some of the tiles have no
>>>> data.
>>> Probably no link with the bug being discussed but I'm curious. What happen when the raster do not have a nodata value defined and you have to pad some tiles?
>>> Pierre
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Greetings
>> Cheryl
> Bborie Park
> Programmer
> Center for Vectorborne Diseases
> UC Davis
> 530-752-8380
Bborie Park
Programmer
UC Davis
530-752-8380
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120308/74ad37f1/attachment.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120308/74ad37f1/attachment-0001.png>
