[postgis-users] Problem in using Postgis 2.0.0b3 with raster
aperi2007
aperi2007 at gmail.com
Fri Mar 9 05:34:47 PST 2012
>Yes, raster2pgsql is in this folder. So i go through the terminal to
>this folder and run something like that: raster2pgsql -s 4236 -I -C -M
>*.tif -F -t 100x100 public.test > out.sql
>Before that, i go to the pgAdminIII, connect to the localhost and
>create a new database "testing" with template "template_postgis".
>How do i declare in the command line that the database that i want to
>load the image is the new one i just created?
>What i get running the command below is: "out.sql: Permission denied".
>What is wrong with this process or what i forget to do?
I will have the same trouble.
After same tests I found that the creation and load of postgis rasters
work only with the "postgres" account.
Otherwise it return me the same your "permission denied".
Andrea.
