[postgis-users] [PostGIS] ERROR: could not load library "/usr/pgsql-9.1/lib/postgis-2.0.so"
GeoFox
Edison.Tam at ngc.com
Mon Mar 12 15:32:39 PDT 2012
Hi everyone,
I am trying to compile PostGIS 2.0 beta 2 on my linux machine. Everything
went well but when I try to create extension postgis, the following error
shows up:
ERROR: could not load library "/usr/pgsql-9.1/lib/postgis-2.0.so":
libjson.so.0: cannot open shared object file: No such file or directory
the file postgis-2.0.so is certainly present under /usr/pgsql-9.1/lib/ but
it is complaining. Any idea why?
I have enclosed a scrip of what I did:
#Linux version
#Compiling GEOS
cd /var/lib/pgsql/required/geos
bzip2 -d -c geos-3.3.2.tar.bz2 | tar xvf -
cd geos-3.3.2
./configure --prefix=/var/lib/pgsql/required/geos/rel-3.3.2
make
make install
#--->Copy everything from /var/lib/pgsql/required/geos/rel-3.3.2 to
/usr/pgsql-9.1
#Compiling Proj4
cd /var/lib/pgsql/required/proj
tar xvfz proj-4.7.0.tar.gz
cd proj-2.7.0
cd nad
unzip ../../proj-datumgrid-1.5.zip
cd ..
./configure --prefix=/usr/pgsql-9.1 --enable-shared --disable-static
make
make install
#export PROJSO=/usr/pgsql-9.1/lib/libproj.so
#Compiling LibXML2
cd /var/lib/pgsql/required/libxml
tar xvfz libxml2-2.7.8.tar.gz
cd libxml2-2.7.8
./configure --prefix=/var/lib/pgsql/required/libxml/rel-2.7.8
--enable-shared
make
make install
#--->Copy everything from /var/lib/pgsql/required/libxml/rel-2.7.8 to
/usr/pgsql-9.1
#Compiling GDAL
cd /var/lib/pgsql/required/gdal
tar xvfz gdal-1.9.0.tar.gz
cd gdal-1.9.0
./configure --with-libtiff=internal
--prefix=/var/lib/pgsql/required/gdal/rel-1.9.0
make
make install
#--->Copy everything from /var/lib/pgsql/required/gdal/rel-1.9.0 to
/usr/pgsql-9.1
export LDFLAGS="-L/var/lib/pgsql/required/gdal/rel-1.9.0/lib"
#Compiling JSON-C
cd /var/lib/pgsql/required/json-c
tar xvfz json-c-0.9.tar.gz
cd json-c-0.9
./configure --prefix=/var/lib/pgsql/required/json-c/rel-0.9
make clean
make
make install
##--->Copy everything from /var/lib/pgsql/required/json-c/rel-0.9 to
/usr/pgsql-9.1
#Compiling PostGIS
cd /var/lib/pgsql/postgis
tar xvfz postgis-2.0.0beta2SVN.tar.gz
cd postgis-2.0.0beta2SVN
./configure \
--prefix=/usr/pgsql-9.1/ \
--with-xml2config=/var/lib/pgsql/required/libxml/rel-2.7.8/bin/xml2-config
--with-pgconfig=/usr/pgsql-9.1/bin/pg_config \
--with-geosconfig=/var/lib/pgsql/required/geos/rel-3.3.2/bin/geos-config \
--with-projdir=/usr/pgsql-9.1 \
--with-gdalconfig=/var/lib/pgsql/required/gdal/rel-1.9.0/bin/gdal-config \
--with-jsondir=/var/lib/pgsql/required/json-c/rel-0.9 \
--with-gettext=no
make clean
make
make install
Edison Tam
NGC SWE
US
View this message in context: http://postgis.17.n6.nabble.com/PostGIS-ERROR-could-not-load-library-usr-pgsql-9-1-lib-postgis-2-0-so-tp4571978p4571978.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
