[postgis-users] Simplify a perfect (hierarchical) partition of polygons (ST_SimplifyPreserveTopology and friends)
Stephen Woodbridge woodbri at swoodbridge.com
Tue Mar 13 09:21:07 PDT 2012
Martin,
The reference to "follow the yellow brick roads" is indeed a reference
to the Wizard of OZ and could be interpreted as to set out on a journey
full of perils and unknowns. :)
That said, there have been a lot of posts on the list about using
topology. The idea would be to load your polygons into a topology then
simplify the edges, and extract you polygons again.
https://www.google.com/#q=postgis+topology
Will get you most of the links you need to get started.
-Steve
On 3/13/2012 1:51 AM, Martin Tomko wrote:
> Hi strk,
> Hm, that did not help me much. Would you have any pointers on how to
> proceed? So far, I found out that it is the Wizard of Oz, so I guess I
> will continue by reading it… ;)
>     - maybe try some tricks using the Postgis2.0 planar topology functions
> Follow the yellow brick road !
> --strk;
> Martin Tomko, PhD.
> Senior Project Manager, Information Infrastructure Design, AURIN
> Level 5, Architecture Building
> University of Melbourne VIC 3010
> AUSTRALIA
> T: +61 3 9035 3298
> E: tomkom at unimelb.edu.au < mailto:tomkom at unimelb.edu.au >
> W: www.aurin.org.au <www.aurin.org.au>
> W: http://www.tomko.org
> postgis-users mailing list
