[postgis-users] Problems with st_distance
Stuart Guthrie
stuartguthrie at gmail.com
Tue Mar 13 20:38:52 PDT 2012
Yes, the issue was where 1 riley st is. It was not where I thought so the
points on the map I was using were not apples and apples.
Thanks again for your help, Postgis works fine.
On Wed, Mar 14, 2012 at 8:37 AM, Stuart Guthrie <stuartguthrie at gmail.com>wrote:
> Thanks Nicklas and Charles for your help. I'm a babe in the woods with
> this even after reading the postgis book. Lots of new terminology.
> I'll check your information today and report back to the list.
> ST_Distance(geog,geog) is supposed to report only in meters according to
> the documentation.
> http://www.postgis.org/documentation/manual-svn/ST_Distance.html
> "For geography type defaults to return the minimum distance around WGS 84
> spheroid between two geographies in meters. "
> I'm thinking it' a planar vs spheriod thing. I'll do the same as Nicklas
> and check on Google Earth.
> The trick with GIS is that it's not like picking up a new API set, you've
> got a whole world of scientific terms to start understanding!
> Again, thanks very much for your help. Great list!
> On Tue, Mar 13, 2012 at 11:26 PM, Nicklas Avén <nicklas.aven at jordogskog.no
> > wrote:
>> Hallo again
>> Stuart, what makes you say that you know the distance is 1800 meters?
>> I just measured by hand in google earth and I get the same answer as
>> PostGIS there about 1180 meters.
>> I think you have been tricked by some application using web mercator
>> projection in the first.
>> Google earth, like PostGIS geography knows how to calculate distances on
>> a sphere or spheroid which for instance google maps doesn't do since it
>> is a flattened globe.
>> HTH
>> Nicklas
>> On Tue, 2012-03-13 at 12:50 +0100, Nicklas Avén wrote:
>> > Sorry, wrong from me
>> > Something is wrong of course if the answer is 1179 compared to 1800. My
>> > brain was on vaccation
>> > /Nicklas
>> > On Tue, 2012-03-13 at 12:48 +0100, Nicklas Avén wrote:
>> > > The geography type distance calculations gives answers in meters from
>> > > unprojected data (4326).
>> > > I see no erason to belive that the postgis answer is wrong, especially
>> > > not when Stuart says he knows the distance is 1800 meters and he gets
>> > > 1179.61 meters from PostGIS.
>> > > I don't know anything about that draft-logic site but I would
>> definitly
>> > > rely more on the PostGIS answer.
>> > > The measurments on Bing, Google maps and so on will be wrong since the
>> > > webmercator projection 913900 is a flattened globe. How could it be
>> > > correct?
>> > > /Nicklas
>> > > On Tue, 2012-03-13 at 07:37 -0400, Charles Galpin wrote:
>> > > > The distance should be in the projection units, which for 4326 is
>> > > > decimal degrees, and if you want meters you'll need to convert the
>> > > > results to meters.
>> > > > But first, I suspect your data is not in 4326 then if you get 1179.
>> > > > Make sure you are using the SRID when inserting them
>> > > > > update address set geog=ST_GeographyFromText('POINT('||
>> > > > > lon||' '||lat||')',4326) where id=?;
>> > > > Also see
>> > > > http://postgis.refractions.net/docs/ST_Distance.html
>> > > > hth
>> > > > charles
>> > > > On Mar 13, 2012, at 2:58 AM, Stuart Guthrie wrote:
>> > > > > Could it be returning a distance in decimal miles? I'm out by
>> around
>> > > > > 1.6 - 1.6km = 1mile?
>> > > > > On Tue, Mar 13, 2012 at 5:43 PM, Stuart Guthrie
>> > > > > <stuartguthrie at gmail.com> wrote:
>> > > > > OK, I'm a newbie to postgis but an old-timer with open
>> > > > > source in general.
>> > > > > Sorry to bother everyone but this problem is driving me a
>> > > > > little nuts.
>> > > > > I've bought the 'postgis in action' book and now I think I
>> > > > > still know nothing.
>> > > > > I'm trying to store long lats and do queries on them to
>> > > > > establish distance and use that for reporting.
>> > > > > I'm using this to update the table 'address'
>> > > > > lon||' '||lat||')') where id=?;
>> > > > > the address table field 'geog' has this definition:
>> > > > > geog geography(Point,4326)
>> > > > > When I compare two addresses that I know are around 1800m
>> > > > > apart I get this:
>> > > > > select a.addressline2, a.suburb, ST_Y(a.geog::geometry),
>> > > > > ST_X(a.geog::geometry),
>> > > > > b.addressline2,b.suburb,ST_Y(b.geog::geometry),
>> > > > > ST_X(b.geog::geometry), ST_distance(a.geog,b.geog ) from
>> > > > > address a join address b on b.id=41491 where a.id=1238 ;
>> > > > > addressline2 | suburb | st_y | st_x |
>> > > > > st_distance
>> > > > > 140 Sussex St | Sydney | -33.8692429 | 151.2036312 | 1
>> > > > > Riley Street | Surry Hills | -33.8726426 | 151.2157115 |
>> > > > > 1179.61881540556
>> > > > > Postgis says they are 1179.61m apart.
>> > > > _______________________________________________
>> > > > postgis-users mailing list
>> > > > postgis-users at postgis.refractions.net
>> > > > http://postgis.refractions.net/mailman/listinfo/postgis-users
> Best regards
> Stuart Guthrie
> (m) 0403 470 123
Best regards
Stuart Guthrie
(m) 0403 470 123
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120314/54b41a27/attachment.html>
