[postgis-users] Are there any Ubuntu PPAs that serve PostGIS 2.0 beta releases?
Skye Book
skye.book at gmail.com
Thu Mar 15 11:56:18 PDT 2012
Looks awesome, Charlie. I'll definitely be giving this a shot today :)
-Skye
On Mar 15, 2012, at 1:40 PM, Charlie Sharpsteen wrote:
> On Wednesday, March 14, 2012 8:18:35 AM UTC-7, Charlie Sharpsteen wrote:
> On Wednesday, March 14, 2012 12:02:24 AM UTC-7, Sandro Santilli wrote:
> On Tue, Mar 13, 2012 at 07:50:32PM -0700, Charlie Sharpsteen wrote:
> > I was wondering if anyone has a Personal Package Archive for Ubuntu that is
> > tracking the 2.0 beta releases. I looked at the UbuntuGIS and Postgis
> > project pages on Launchpad, but the only releases listed there were for
> > 1.5.x. Even the unstable repostory of UbuntuGIS was still tracking 1.5.x.
> I'm not aware of any. It'd be very welcome if you want to setup one.
> --strk;
> Allright, I'll take a shot at it. Looks like there is a Launchpad repository that is synching with PostGIS SVN every 6 hours or so---perhaps I can get a nightly build set up.
> -Charlie
> Ok, I now have a nightly build set up that is tracking the PostGIS trunk. Binaries are being built for Oneric (11.11) and Precise (12.04-dev) and can be installed thusly:
> sudo apt-add-repository ppa:sharpie/postgis-nightly
> sudo apt-get update
> sudo apt-get install postgresql-9.1-postgis
> Caveats:
> No build of `postgis` or `libpostgis-java`, the only package provided is `postgresql-9.1-postgis` which contains the PostGIS plugins, extensions and command line tools.
> Builds against GEOS 3.2.2, supplied by the standard Ubuntu repositories, thus the topology extension is unavailable.
> Builds against GDAL 1.7.0, supplied by the standard Ubuntu repositories, thus some raster functionalities are unavailable.
> The raw materials that went into creating this build were the PostGIS repository on Launchpad which synchs with the upstream SVN trunk ~every 6 hours:
> https://code.launchpad.net/~registry/postgis/trunk
> This repostory can be cloned using bazaar via `bzr branch lp:postgis`. The other component is the official Ubuntu PostGIS repository that contains the debian packaging materials:
> https://code.launchpad.net/~ubuntu-branches/ubuntu/precise/postgis/precise
> This repository can be cloned using `bzr branch lp:ubuntu/postgis`. My strategy was to fork `lp:ubuntu/postgis`, edit the contents of the debian subdirectory to make it compatible with 2.0-dev and then publish the edited fork to Launchpad under my `+junk` section. After this was done, I set up a `bzr-builder` recipe that fuses `lp:postigs`, which tracks the upstream PostGIS repo, with the debian subdirectory contained in `lp:~sharpie/+junk/postgis`, which contains my edited packaging info, to create a nightly build:
> # bzr-builder format 0.3 deb-version {debupstream}~r{revno}~ppa{revno:packaging}
> lp:postgis
> nest-part packaging lp:~sharpie/+junk/postgis debian debian
> Pretty slick. I will ponder upgrading GEOS and GDAL and setting up a stable build for the most recent beta releases.
> -Charlie
> postgis-users mailing list
____________
Skye Book
(516) 816-4762
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120315/6a698ecc/attachment.html>
