[postgis-users] creating a grid; transform error
Salvatore Larosa lrssvtml at gmail.com
Fri Mar 16 02:13:36 PDT 2012
I'm trying the query and I get this:
ERROR: AddToPROJ4SRSCache: could not parse proj4 string '+proj=merc
+a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0 +k=1.0
+units=m +nadgrids=@null
+no_defs' unknown projection id
SQL state: XX000
In spatial_ref_sys SELECT proj4text FROM spatial_ref_sys where srid =
900913
"+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0 +x_0=0.0 +y_0=0
+k=1.0 +units=m +nadgrids=@null +no_defs"
While the command cat /usr/share/proj/epsg | grep <900913>
return nothing!
Must I to add the string in EPSG file, too?
Il giorno ven, 16/03/2012 alle 18.00 +1300, Mike Toews ha scritto:
> On 16 March 2012 16:52, Puneet Kishor <punk.kish at gmail.com> wrote:
> > Thanks Mike... works.
> I just noticed there was something funny going on with the
> generate_series cross product, so it wasn't producing as many rows. It
> should be:
> SELECT ST_Transform(ST_MakeEnvelope(minx, miny, maxx, maxy, 4326),
> 900913) the_geom
> FROM (
>     SELECT lng minx, lat miny, (lng + 1) maxx, (lat + 1) maxy
>     FROM generate_series(-85, 84, 1) lat,
>          generate_series(-180, 179, 1) lng
>     ORDER BY lng, lat
> ) lat_lng;
> -Mike
> postgis-users mailing list
