[postgis-users] How compute the stats from a raster table.
Andrea Peri aperi2007 at gmail.com
Fri Mar 16 02:38:41 PDT 2012
>SELECT (ST_SummaryStats(..)).* FROM ...
>Should show you "labels" to better understand.
Yes, thx, now it report me this:
 count | sum | mean | stddev | min | max
 10000 |   0 |    0 |      0 |   0 |   0
>I guess you could run aggregates on the single columns of the stats, like:
>WITH stats AS ( SELECT (ST_SummaryStats(..)).* FROM ... )
>SELECT sum(count) as count, sum(sum) ... FROM stats;
Thx , strk.
Running this query
WITH stats AS (
  SELECT
    (ST_SummaryStats(rast)).*
  FROM
    my_schema.my_table
SELECT
  sum(sum) as sum,
  avg(mean) as mean,
  avg(stddev) as stddev,
  min(min) as min,
  max(max) as max
FROM
 stats
I have the report I need.
 164020000 | 620088072 | 3.78056378490428 | 2.01499851432122 |   0 | 245
(1 riga)
>I guess it could be useful to define an aggregate taking
>"SummaryStats" type in input so you could do something like:
>SELECT (ST_SummaryStatsAgg(ST_SummaryStats(xx))).* FROM myrast;
I guess it should better.
Andrea Peri
qwerty àèìòù
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120316/78c3474e/attachment.html>
