[postgis-users] creating a grid; transform error
Salvatore Larosa
lrssvtml at gmail.com
Fri Mar 16 03:57:32 PDT 2012
Il giorno ven, 16/03/2012 alle 11.40 +0100, Sandro Santilli ha scritto:
> On Fri, Mar 16, 2012 at 10:13:36AM +0100, Salvatore Larosa wrote:
> > While the command cat /usr/share/proj/epsg | grep <900913>
> > return nothing!
> Thake the angle braces out. They are even dangerous.
> --strk;
thanks but the problem was not the angle braces. I posted the string in
the wrong way!
I had to insert the following line in EPSG file, why was not there!
<900913> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
+x_0=0.0 +y_0=0 +k=1.0 +units=m +nadgrids=@null +no_defs <>
I still have the same problem!
Anymore hint?
