[postgis-users] PostGIS2beta4svn won't configure / build
Paul Ramsey
pramsey at opengeo.org
Sun Mar 18 10:47:08 PDT 2012
Add /usr/local/bin to your path (if that's where you installed it) or
specify your gdal-config explicitly.
P
On Fri, Mar 16, 2012 at 8:10 AM, White, Richard
<Richard.White at infoterra-global.com> wrote:
> Hi,
> I am trying to build PostGIS2beta4svn on Ubuntu Server 11.10 64bit and I
> get the following error message when trying to configure;
> "Checking for library containing GDALAllRegister...no"
> "configure:error: could not find gdal"
> Gdal is installed and built correctly.
> Any ideas?
> Thanks.
> R.
> Infoterra Ltd. Is part of the Astrium GEO-Information Services Division and a wholly owned subsidiary of Astrium, Europe's leading space systems and services specialist.
> Disclaimer. The information contained in this e-mail and its attachments are confidential and intended only for the use of the named addressee(s). If you are not the intended addressee, please do not read, copy, use or disclose this message or its attachments. If you have received this message in error, please notify the sender immediately and delete or destroy all copies of this message and attachments in all media. Any views or opinions expressed are solely those of the author and do not necessarily represent those of Infoterra Ltd and shall not form part of any binding agreement.
> Infoterra Limited a company registered in England under number 2359955 and having its registered office at Atlas House, 41 Wembley Road, Leicester, LE3 1UT. VAT number GB 476 0468 27.
> P Before printing, think about the environment
> postgis-users mailing list
