[postgis-users] Removed double quotes from column and table names
Simon Greener simon at spatialdbadvisor.com
Mon Mar 19 03:58:00 PDT 2012
Birgit,
I realise that I can do this manually. I was looking for a method for doing
this at the point of loading the shapefile into PostGIS using QGIS. I will
have a look at ogr2ogr to see if that helps.
Thanks
regards
Simon
On Mon, 19 Mar 2012 21:00:27 +1100, Birgit Laggner <birgit.laggner at vti.bund.de> wrote:
> Hi Simon,
> I would think RENAME would do what you want:
> ALTER TABLE schema."TableName" RENAME TO tablename;
> ALTER TABLE schema.tablename RENAME COLUMN "ColumnName" TO columnname;
> Hope that helps,
> Birgit.
> Am 19.03.2012 06:03, schrieb Simon Greener:
>> Is there any way to remove the double quotes created around a table or
>> its column names?
>> My names do NOT include spaces but do include mixed case. I wish to
>> remove the quotes and
>> lower case all names.
>> How can this be done?
>> Note: the tables were loaded by QGIS into PostgreSQL. In the DBF file
>> the names are mixed case.
>> I can see nothing in the PostGIS/QGIS plugin SPIT that allows me to
>> tell it to lower case all names.
>> S
> postgis-users mailing list
Holder of "2011 Oracle Spatial Excellence Award for Education and Research."
SpatialDB Advice and Design, Solutions Architecture and Programming,
Oracle Database 10g Administrator Certified Associate; Oracle Database 10g SQL Certified Professional
Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, FME, Radius Topology and Studio Specialist.
39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
Website: www.spatialdbadvisor.com
   Email: simon at spatialdbadvisor.com
   Voice: +61 362 396397
Mobile: +61 418 396391
Skype: sggreener
Longitude: 147.20515 (147° 12' 18" E)
Latitude: -43.01530 (43° 00' 55" S)
GeoHash: r22em9r98wg
NAC:W80CK 7SWP3
