[postgis-users] Removed double quotes from column and table names
Simon Greener simon at spatialdbadvisor.com
Tue Mar 20 15:52:16 PDT 2012
Thanks all for the suggestions.
S
On Tue, 20 Mar 2012 05:10:28 +1100, Lee Hachadoorian <Lee.Hachadoorian+L at gmail.com> wrote:
> This option is not available via SPIT, but ogr2ogr does allow it as a layer creation option:
> "LAUNDER: This may be "YES" to force new fields created on this layer to have their field names "laundered" into a form more compatible with PostgreSQL. This converts to lower case and converts some special characters like "-" and "#" to "_". If "NO" >exact names are preserved. The default value is "YES". If enabled the table (layer) name will also be laundered." (http://www.gdal.org/ogr/drv_pg.html)
> Also shp2pgsql defaults to forcing lower case names (the correct choice, IMHO), but has an option to specify preserving case.
> Best,
> --Lee
> On Mon, Mar 19, 2012 at 6:58 AM, Simon Greener <simon at spatialdbadvisor.com> wrote:
>> Birgit,
>> I realise that I can do this manually. I was looking for a method for doing
>> this at the point of loading the shapefile into PostGIS using QGIS. I will
>> have a look at ogr2ogr to see if that helps.
>> Thanks
>> regards
>> Simon
>> On Mon, 19 Mar 2012 21:00:27 +1100, Birgit Laggner <birgit.laggner at vti.bund.de> wrote:
>>> Hi Simon,
>>> I would think RENAME would do what you want:
>>> ALTER TABLE schema."TableName" RENAME TO tablename;
>>> ALTER TABLE schema.tablename RENAME COLUMN "ColumnName" TO columnname;
>>> Hope that helps,
>>> Birgit.
>>> Am 19.03.2012 06:03, schrieb Simon Greener:
>>>> Is there any way to remove the double quotes created around a table or
>>>> its column names?
>>>> My names do NOT include spaces but do include mixed case. I wish to
>>>> remove the quotes and
>>>> lower case all names.
>>>> How can this be done?
>>>> Note: the tables were loaded by QGIS into PostgreSQL. In the DBF file
>>>> the names are mixed case.
>>>> I can see nothing in the PostGIS/QGIS plugin SPIT that allows me to
>>>> tell it to lower case all names.
>>>> S
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> --Holder of "2011 Oracle Spatial Excellence Award for Education and Research."
>> SpatialDB Advice and Design, Solutions Architecture and Programming,
>> Oracle Database 10g Administrator Certified Associate; Oracle Database 10g SQL Certified Professional
>> Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, FME, Radius Topology and Studio Specialist.
>> 39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
>> Website: www.spatialdbadvisor.com
>> Email: simon at spatialdbadvisor.com
>> Voice: +61 362 396397
>> Mobile: +61 418 396391
>> Skype: sggreener
>> Longitude: 147.20515 (147° 12' 18" E)
>> Latitude: -43.01530 (43° 00' 55" S)
>> GeoHash: r22em9r98wg
>> NAC:W80CK 7SWP3
Skype: sggreener
NAC:W80CK 7SWP3
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120321/ecca91ca/attachment.html>
