[postgis-users] ST_Buffer + grid problem
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Wed Mar 21 12:46:58 PDT 2012
> I am not sure if this is possible, but I have computed (using ST_Buffer) a sort of
> buffer around several LINESTRINGs. Now I would like to lay some sort of grid of
> say 1m^2 cell size on top of this collection of geometries and then compute the
> intersection... so in the end I would like to for example, know that grid cell ID = 1
> intersects with buffers 1 and 10, grid cell 2 intersects with buffers 7, 10 etc..
> Is there a simple way of doing this in postgis? Maybe someone could point me to
> some documentation of how I can generate such a grid in postgis and maybe
> then I can use just ST_Intersect once I have these two geometries?
With the raster type you can now easily create a vector grid like this:
CREATE TABLE vectorgrid AS
SELECT (gvxy).geom, ((gvxy).x - 1) * rwidth + (gvxy).y gridid
FROM (SELECT ST_PixelAsPolygons(rast) gvxy, ST_Width(rast) rwidth
FROM (SELECT ST_AsRaster(ST_Extent(geom)::geometry, 1.0, 1.0) rast
FROM yourbuffertable
) foo1
) foo2;
Make sure a spatial index exist on both tables:
CREATE INDEX yourbuffertable_geom_idx ON yourbuffertable USING gist (geom);
CREATE INDEX vectorgrid _geom_idx ON vectorgrid USING gist (geom);
You can then perform a normal intersect query:
CREATE TABLE interresult AS
SELECT b.bufferid, g.gridid, ST_Intersection(g.geom, b.geom) geom
FROM vectorgrid g, yourbuffertable b
WHERE ST_Intersects(g.geom, b.geom);
Pierre
