[postgis-users] ST_Buffer + grid problem
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Thu Mar 22 06:53:22 PDT 2012
I guess this is related to a GDAL problem where you cannot create a raster using ST_AsRaster with pixel size smaller than 1. Was this fixed Bborie?
Ed could you reduce the list of geometries passed to ST_Extent to one and write it as ST_GeomfromText so we can debug this more easily?
Pierre
> -----Original Message-----
> From: manohar.kaul at gmail.com [mailto:manohar.kaul at gmail.com] On Behalf
> Of Ed Linde
> Sent: Thursday, March 22, 2012 9:45 AM
> To: Pierre Racine
> Cc: PostGIS Users Discussion
> Subject: Re: [postgis-users] ST_Buffer + grid problem
> Hi Pierre,
> So I am trying to have a 4meter by 4meter cell and I converted 4meters to
> degrees, because I think ST_Extent will compute it in degrees as my geometry is
> in srid 4326. But I get this GDAL error which I have no clue what it means. Any
> ideas how I can fix it? Also I noticed that if I set it to 1.0, 1.0 I get
> 21 rows but the gridid isn't continuous either (which is weird).
> CREATE TABLE vectorgrid AS
> SELECT (gvxy).geom, ((gvxy).x - 1) * rwidth + (gvxy).y gridid FROM (SELECT
> ST_PixelAsPolygons(rast) gvxy, ST_Width(rast) rwidth
> FROM (SELECT ST_AsRaster(ST_Extent(way_geom)::geometry, 0.000036,
> 0.000036) rast
> FROM buffers
> ) foo1
> ) foo2;
> ERROR: rt_raster_gdal_rasterize: Unable to add band to GDALDataset
> ********** Error **********
> ERROR: rt_raster_gdal_rasterize: Unable to add band to GDALDataset SQL state:
> XX000
> On Thu, Mar 22, 2012 at 2:13 PM, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> wrote:
> You can control how the grid is aligned by using more ST_AsRaster
> parameters. See:
> http://postgis.refractions.net/documentation/manual-
> svn/RT_ST_AsRaster.html
> If you want it to align on your point, just align it on your points...
> Pierre
> On Behalf
> > Of Ed Linde
> > Sent: Thursday, March 22, 2012 9:05 AM
> > To: PostGIS Users Discussion
> > Cc: Pierre Racine
> > Hi Pierre,
> > Thanks for the grid idea last night. I have a problem though, I want to
> have a 4m
> > by 4m cell sized grid over my buffer geometries which are in SRID =
> 4326. And
> > then I have another data set of 2D points which are also in SRID
> 4326...
> > wondering how I can figure out from just a given (lat,long) which cell
> ID in the
> > buffer grid it would belong to? I am thinking that I might run into
> "alignment
> > issues" because shouldn't the extent of the grid be exactly the same
> on the 2D
> > point cloud as well, so that the grid cell IDs will match? Unless I am
> missing
> > something here?
> > Cheers,
> > Ed
> > On Wed, Mar 21, 2012 at 8:46 PM, Pierre Racine
> > wrote:
> > > I am not sure if this is possible, but I have computed (using
> ST_Buffer)
> > a sort of
> > > buffer around several LINESTRINGs. Now I would like to lay some
> sort
> > of grid of
> > > say 1m^2 cell size on top of this collection of geometries and
> then
> > compute the
> > > intersection... so in the end I would like to for example, know
> that grid
> > cell ID = 1
> > > intersects with buffers 1 and 10, grid cell 2 intersects with buffers
> 7, 10
> > etc..
> > > Is there a simple way of doing this in postgis? Maybe someone
> could
> > point me to
> > > some documentation of how I can generate such a grid in postgis
> and
> > maybe
> > > then I can use just ST_Intersect once I have these two
> geometries?
> > With the raster type you can now easily create a vector grid like
> this:
> > FROM (SELECT ST_PixelAsPolygons(rast) gvxy, ST_Width(rast)
> rwidth
> > FROM (SELECT ST_AsRaster(ST_Extent(geom)::geometry,
> 1.0,
> > 1.0) rast
> > FROM yourbuffertable
> > ) foo1
> > ) foo2;
> > Make sure a spatial index exist on both tables:
> > CREATE INDEX yourbuffertable_geom_idx ON yourbuffertable
> USING
> > gist (geom);
> > CREATE INDEX vectorgrid _geom_idx ON vectorgrid USING gist
> > (geom);
> > You can then perform a normal intersect query:
> > CREATE TABLE interresult AS
> > SELECT b.bufferid, g.gridid, ST_Intersection(g.geom, b.geom)
> geom
> > FROM vectorgrid g, yourbuffertable b
> > WHERE ST_Intersects(g.geom, b.geom);
> > Pierre
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
