[postgis-users] ST_Buffer + grid problem
Ed Linde edolinde at gmail.com
Thu Mar 22 12:44:34 PDT 2012
Pierre,
Once I have this raster + buffer geometry intersected, is there an easy way
to visualize this? Say in Quantum GIS?
Will I be able to see the raster and the buffer together to check manually
if the intersection looks fine?
Cheers,
Ed
On Thu, Mar 22, 2012 at 6:30 PM, Ed Linde <edolinde at gmail.com> wrote:
> I am on Fedora 15 x86_64
> On Thu, Mar 22, 2012 at 6:28 PM, Pierre Racine <
> Pierre.Racine at sbf.ulaval.ca> wrote:
>> > I can try that ... but I am away from the office now. So will have to
>> give it a shot
>> > tomorrow morning! :) Will let you know if that fixes it. But should I
>> download
>> > the source and build GDAL 1.9?
>> On which OS are you? You should not have to build it as it has been
>> released a while ago.
>> Otherwise you can also replace
>> ST_AsRaster(ST_Extent(way_geom)::geometry, 0.000036, 0.000036)
>> with the proper ST_MakeEmptyRaster() call:
>> http://postgis.refractions.net/documentation/manual-svn/RT_ST_MakeEmptyRaster.html
>> Pierre
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120322/5e2f3f4c/attachment.html>
