[postgis-users] ST_Buffer + grid problem
Ed Linde
edolinde at gmail.com
Thu Mar 22 14:01:37 PDT 2012
Hi Pierre,
The idea is that I want to build this uniform grid on the road geometry and
like you mention it has dimensions 1020x24798. I want to assign each cell a
unique cell ID based on some formula like you had earlier ... x*width + y
to get a 1D cell ID from (x,y). Hopefully I can do this on just (lat.long)
of srid 4326 directly. Then I need to
intersect it to the buffers around the roads which I think should be easy
once I have a raster, so this is just a normal intersect. Now I should know
each cell and what road buffer it belongs to! Then on my second data set
which is a massive point cloud with srid = 4326 as well, I just want to
pass through it ONCE and compute in which cell it falls and hence associate
a point with a road buffer. Hope that made sense :)
Cheers,
Ed
On Thu, Mar 22, 2012 at 9:53 PM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca>wrote:
> 1020x24798 so more than 25 000 000 polygons... or pixels...
> So if I understand well you want to assign some values to each of those
> cells based on a vector coverage (of how many polygons)?
> > -----Original Message-----
> > From: postgis-users-bounces at postgis.refractions.net [mailto:
> postgis-users-
> > bounces at postgis.refractions.net] On Behalf Of Ed Linde
> > Sent: Thursday, March 22, 2012 4:43 PM
> > To: PostGIS Users Discussion
> > Subject: Re: [postgis-users] ST_Buffer + grid problem
> > So far no proper raster, because the following failed, but maybe the
> polygon
> > gives us an idea? This polygon is the extent of all the road geometries
> in
> > Denmark. Also I remember that when you did the raster at your end you
> said it
> > worked. Is 0.000036 degrees = 4m correct if I want to get a 4m by 4m
> cell sized
> > uniform raster grid?
> > select ST_AsRaster( ST_GeomFromText('POLYGON((8.07734039737749
> > 54.4984986588244,8.07734039737749 57.7505109647578,15.1919565742587
> > 57.7505109647578,15.1919565742587 54.4984986588244,8.07734039737749
> > 54.4984986588244))'), 0.000036, 0.000036);
> > On Thu, Mar 22, 2012 at 9:39 PM, Pierre Racine <
> > wrote:
> > > Thanks. The raster I need to visualise is a 4m by 4m grid on the
> entire
> > map of
> > > Denmark! :) So do you classify that as a large raster? If so is
> there a
> > way to see a
> > > portion of it or something?
> > > I just want to manually check for a few areas on the map that the
> > intersection
> > > indeed works as expected and things haven't gone awry thanks to
> > projection
> > > differences or that I had degrees instead of meters or some such
> > thing. Well, I
> > > still have to first test if this GDAL upgrade will fix things
> and if make
> > empty raster
> > > .. makes a difference.
> > That must be big but Danemark is a small country ;-) Only width and
> > height tell you if a raster is big.
> > In the database, your grid is a set of rectangular geometry (how
> many?)
> > or just a big raster now (width & height)?
> > postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120322/ae5aca08/attachment.html>
