[postgis-users] Slony and PostGIS problem
Paul Ramsey pramsey at opengeo.org
Fri Mar 23 09:10:05 PDT 2012
On Fri, Mar 23, 2012 at 6:18 AM, Brian Peschel <brianp at occinc.com> wrote:
> Figured I would start here since I suspect this is a PostGIS problem more
> than a Slon problem.
> My main node is a Fedora 8, Postgres 8.3.1, Slon 1.2.20, and PostGIS 1.3.
>  This is being replicated via slon to an Ubuntu 10, Postgres 8.4.11, Slon
> 1.2.20, and PostGIS 1.4.  My table looks like this:
> Table "public.ml_polygon"
>  Column |   Type   | Modifiers
>  msg_no | integer  | not null
>  rev_no | integer  | not null
>  geom   | geometry |
> Indexes:
>    "ml_polygon_pkey" PRIMARY KEY, btree (msg_no, rev_no)
>    "ml_geom_idx" gist (geom)
> Check constraints:
>    "enforce_dims_geom" CHECK (ndims(geom) = 2)
>    "enforce_srid_geom" CHECK (srid(geom) = 4269)
> I have some bad geoms in the database, basically polygons with invalid point
> counts:
>  70650590 |      1 | POLYGON((-90.869358 38.839444,-90.869358
> 38.839447,-90.869358 38.839444))
> In PostGIS 1.3, this is perfectly acceptable (even though it is bad).  In
> 1.4, this doesn't work and a select gives you this error:
> ERROR:  geometry requires more points
> which also appears in my Postgres log.  Google tells me this was an issue
> with early PostGIS 1.4 versions.  Okay.
> But I need to fix these.  So on my main node, I did this:
> update ml_polygon set geom = ST_SetSRID('POLYGON((-90.869358
> 38.839444,-90.869358 38.839447,-90.869358 38.839447,-90.869358 38.839444))',
> 4269) where msg_no = 70650590 and rev_no = 1;
> which happily updated my main node.  And nothing showed up on by second
> node.  No errors messages anywhere I could find.  New inserts in this table
> in my main node showed up on the second node, so I know slony is working,
> but this update never showed up.
> I did a different update (to an existing 16 point polygon) and the updated
> showed up in my second node.  I was worried that slony wouldn't pick up
> updates of a geometry column, but this proved to me that wasn't the problem.
>  I re-did the first insert and, surprise, surprise, it worked fine.
> So, I tried a different record with the same 3 point problem, and it showed
> up on the second node.
> Needless to say, I am very confused.  Not only is the constancy of what
> works and fails a problem, but the fact the slony copy (apparently) failed
> with no error messages concerned me also.  Can I trust the data in my second
> node?
Based on the description I would think not. If you insert another new
bad geometry in the master, does it show up on the slave? If the bad
geometries can't traverse from 1.3 to 1.4 you'll have a systemic chunk
of missing data.
> Any thoughts?
> - Brian
> postgis-users mailing list
