[postgis-users] still error
Eman Sayed
eman_sayed80 at yahoo.com
Sat Mar 24 02:28:25 PDT 2012
hi,
after alot of revison the error is changed
Message: Object doesn't support this property or method
Line: 139
Char: 681
Code: 0
URI: http://localhost/pmapperegypt/incphp/js/js_session.php?PHPSESSID=vs28he1rerhj8a2frekiaj8sj0
From: Serge Claudio Rafanoharana <rafanoharana at gmail.com>
To: Eman Sayed <eman_sayed80 at yahoo.com>; pmapper-users <pmapper-users at lists.sourceforge.net>
Sent: Friday, March 23, 2012 10:39 PM
Subject: Re: [pmapper-users] still no layers
Hi Sayed,
I don't know what's wrong but I'm just wondering whether it is a problem
related with permission or not... Would you mind to check in that part?
Regards,
Serge
On Sat, Mar 24, 2012 at 2:36 AM, Eman Sayed <eman_sayed80 at yahoo.com> wrote:
> Hi,
> thanks for your reply i made all of that but still the select layer window
> empty after word "Available Layers"
> and the error is
> Message: 'PM.ini.pluginsConfig.layerselect.categories' is null or not an
> object
> Line: 139
> Char: 618
> Code: 0
> *From:* Serge Claudio Rafanoharana <rafanoharana at gmail.com>
> *To:* Eman Sayed <eman_sayed80 at yahoo.com>; pmapper-users <
> *Sent:* Friday, March 23, 2012 2:12 PM
> *Subject:* Re: [pmapper-users] no layers names added
> Hi Sayed,
> Try to define the category name in incphp/locale/your_language
> Something like:
> *config....xml*
> <category name="cat_admin">
> *language_en.php*
> $_sl['cat_adm'] = 'Data Administrative';
> and make sure you followed carefully
> http://svn.pmapper.net/trac/wiki/PluginsLayersManagement
> and that you remove:
> <allGroups>
> </allGroups>
> in your *congig....xml*
> Cheers,
> Serge
> On Fri, Mar 23, 2012 at 6:11 PM, Eman Sayed <eman_sayed80 at yahoo.com>
> wrote:
> > thanks alot for your help i used select layers plugin but it's empty
> > dailoge no layers names appeared
> > From: Chris Jackson <webturtles at gmail.com>
> > Cc: "pmapper-users at lists.sourceforge.net" <
> > Sent: Friday, March 23, 2012 8:27 AM
> > Subject: Re: [pmapper-users] show map layer by combo box
> > Hi
> > How about the layer selection plugin -
> > http://svn.pmapper.net/trac/wiki/PluginsLayersManagement.
> > Chris
> > On 23 Mar 2012 05:15, "Eman Sayed" <eman_sayed80 at yahoo.com> wrote:
> > hi,
> > >i want to make a combo box contain a number of map layers names when the
> > user choose one it will be added on the map.
> > >please help
> > >This SF email is sponsosred by:
> > >Try Windows Azure free for 90 days Click Here
> > >http://p.sf.net/sfu/sfd2d-msazure
> > >_______________________________________________
> > >pmapper-users mailing list
> > >https://lists.sourceforge.net/lists/listinfo/pmapper-users
> Serge
Serge
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120324/a4402e0b/attachment.html>
