[postgis-users] Strange ST_Area problem
Eric Ladner eric.ladner at gmail.com
Sat Mar 24 16:19:53 PDT 2012
On Sat, Mar 24, 2012 at 11:06 AM, Stephen Woodbridge
<woodbri at swoodbridge.com> wrote:
> st_area returns in the same units as the input data. So data in 4326 is
> degrees and you numbers are in degrees squared. If you want the number in
> meters or feet then project then into an appropriate UTM or equal area
> projection.
Ah.. that makes sense.  Would EPSG:32230 be appropriate?  (WGS 72, UTM
zone 30N)  I'm dealing with things roughly in the 30.0 to 31.0N range.
> - Steve
Thanks!
Eric Ladner
