[postgis-users] POSTGIS 2.0 on WIn
Paragon Corporation lr at pcorp.us
Mon Mar 26 19:26:18 PDT 2012
PROJSO  settings shouldn't be necessary anymore because libproj.dll is not
used.
I upgraded the install to use proj 4.8.0 so the dll is now libproj-0.dll
which is what gdal assumes by default.
It's possible I missed a dll and my tests systems already had them -- make
sure you have libproj-0.dll in your bin folder.
I think if postgis is in use it won't be able to copy the dll so you will
probably need to shut down your service / restart and then run the copy
script.
Hope that helps,
Regina
http://www.postgis.us
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Pierre Racine
> Sent: Monday, March 26, 2012 2:23 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] POSTGIS 2.0 on WIn
> > Hi at all,
> > I wished test POSTGIS 2.0 on Win, so after installed on
> WinXP32   PostgreSQL
> > 9.1.1,  and following instruction for  postgis-pg91-binaries-2.0.
> > 0beta4w32 .... but I get the following error
> > "...C:\postgis-pg91-binaries-
> > 2.0.0beta4w32\postgis-pg91-binaries-
> > 2.0.0beta4w32>"C:\Programmi\PostgreSQL\9.1\bin\\psql"  -d
> "testpstg"
> > -c "CREATE EXTENSION postgis;" ERROR:  could not load library
> > "C:/Programmi/PostgreSQL/9.1/lib/postgis-2.0.dll"
> > : unknown error 126 ".
> > Of course 1) postgis-2.0.dll is on the lib dir; 2) I stopped and
> > restared Postgres service; 3) I've tried also another
> installation dir
> > for Postgers in order to prevent eventually "space in name"
> trouble, but...
> > I get the same problem
> > Any hints?
> Try setting the PROJSO to the path of libproj.dll
> Pierre
> postgis-users mailing list
