[postgis-users] What is the detailled meaning of this error?
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Tue Mar 27 10:45:32 PDT 2012
It works even if the srs is a custom one. GDAL needs to refer to its other lists but since we pass the whole srs string it does not need to have the srid defined in its files.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of Bborie Park
> Sent: Tuesday, March 27, 2012 1:42 PM
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] What is the detailled meaning of this error?
> Really? I'll add a check anyways...
> -bborie
> On 03/27/2012 10:32 AM, Pierre Racine wrote:
> > Ok. If I set GDAL_DATA properly it works fine.
> >> [mailto:postgis-users- bounces at postgis.refractions.net] On Behalf Of
> >> Bborie Park
> >> Sent: Tuesday, March 27, 2012 1:19 PM
> >> It means that GDAL doesn't have that projection in its projection list.
> >> I'll need to add a testing function to see if GDAL supports the
> >> particular projection.
> >> -bborie
> >> On 03/27/2012 09:47 AM, Pierre Racine wrote:
> >>> ERROR: rt_raster_gdal_rasterize: Unable to create OSR spatial
> >>> reference using the provided srs: EPSG:42304
> >>> _______________________________________________
> >>> postgis-users mailing list
> >>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> >> Bborie Park
> >> Programmer
> >> Center for Vectorborne Diseases
> >> UC Davis
> >> 530-752-8380
> >> bkpark at ucdavis.edu
> Bborie Park
> Programmer
> UC Davis
> 530-752-8380
