[postgis-users] Break lines at intersections
Horst Düster
horst.duester at kappasys.ch
Wed Mar 28 05:31:30 PDT 2012
-----BEGIN PGP SIGNED MESSAGE-----
Hash: SHA1
Hi
if you work with PostGIS < 2.0 you can use the cleangeometry() function.
http://www.kappasys.ch/pgtools/cleangeometry/cleanGeometry.sql
Regards
Horst
Dr. Horst Düster
Kappasys
Alte Bernstrasse 13
CH-4500 Solothurn
Tel.: +41 (0) 32 514 00 40
Mobil: +41 (0) 76 408 51 06
eMail: horst.duester at kappasys.ch
skype: horstduester
Twitter: moazagotl
Web: www.kappasys.ch
lat: N 47° 12' 06.408" lon: E 7° 32' 13.740"
Am 28.03.2012 12:29, schrieb Pavel Iacovlev:
> Hello,
> Anyone has any ideas/tips of how to break lines at intersections ?
> I have a a layer of lines and I want to break them at intersections
> with them selfs, also (not that important but would be nice) break
> lines forming a collapsed loop, for example 0.0;1.0;0.0 is broken at
> 1.0.
> Currently this can be done in grass with v.clean tool=break,rmdupl but
> it's relatively hard to add GRASS to a web app.
> So far I came up with this query and out of ideas right now:
> SELECT DISTINCT
> gid,
> ST_AsText(intersect_geom),
> ST_Line_Locate_Point(GeometryN(the_geom, 1), intersect_geom) as point_loc1
> FROM
> (SELECT a.gid, ST_Intersection(a.the_geom, b.the_geom) AS
> intersect_geom, a.the_geom
> FROM roads as a, roads as b
> WHERE ST_Intersects(a.the_geom, b.the_geom) AND (a.gid = 1)
> ) AS res1
> WHERE GeometryType(intersect_geom) = 'POINT' -- Need support for
> MULTILINESTRINGS, take start and end point ?
> ORDER BY point_loc1
> which has the following result: http://jsfiddle.net/9RJ8a/
> I have the line, and the point positions on the line, but I can't get
> around how to create my NEW broken lines with
> ST_Line_Substring(geometry a_linestring, float startfraction, float
> endfraction)
> Any suggestion of how to accomplished this ? is the approach correct ?
> any other ideas ?
> postgis-users mailing list
-----BEGIN PGP SIGNATURE-----
Version: GnuPG v1.4.11 (GNU/Linux)
Comment: Using GnuPG with Mozilla - http://enigmail.mozdev.org/
iQEcBAEBAgAGBQJPcwSiAAoJENJq1wkKM7pS6NwH/3PzIeSfjG29wfrPx4mLu7gS
6gAYWk6Lsfp4kUEoy6uJdtGz6iFn3vY2blz1cA9diUrjw00O8m5/8IVFuI0jdyLM
j6tzDbyB7jmXyF6F3TLKfnAakVGenhbcXTeHRL3ojAiKcq8UGsRDQYviQ3WZK9sY
EXP9wJIunhawILOfFXEO68AcRDPLZcaLtZAE/qj4yY+p538M/8PNfuK2rBw6fcVO
dPcug4wDewciPYQBcgKdbRpXtpfh9ytq4xYV16aAA8wVg4lFicldIm4cm8mytOrb
0bYYyFmAHtpBQ2Hv6A7eMxywzF8iQmu8oPl1I6ihPwol3VQ/Tws+nAKbfGKs3bs=
=FgwT
-----END PGP SIGNATURE-----
