[postgis-users] LinearReferencing: measure vertex of linestring?
George Silva
georger.silva at gmail.com
Wed Mar 28 11:19:24 PDT 2012
I guess the best way to do this is to combine the actual line and a
"virtual" line, probably a view, with "measured" points.
This involves a bit of thinking but it might be possible.
George
On Wed, Mar 28, 2012 at 3:03 PM, Stephen Woodbridge <woodbri at swoodbridge.com
> wrote:
> On 3/28/2012 1:26 PM, Andrés Maneiro wrote:
>> On 28/03/12 18:26, Sandro Santilli wrote:
>>> On Wed, Mar 28, 2012 at 06:22:28PM +0200, Andrés Maneiro wrote:
>>> LINESTRINGM(1 0 1,2 0 2,4 0 4)
>> Oh, I get it. And there is a native way in postgis to calibrate the line
>> from a given set of measured points instead of using the ends?
>> If I understand it correctly I could:
>> 1) mylinestringm = ST_AddMeasure(mylinestring, measure_start,
>> measure_end);
>> 2) Add the given set of points to mylinestringm with ST_AddPoint
>> 3) Using ST_SetPoint to move the original vertexes.
>> Is that correct? I'm very interested to know if there is a more direct
>> and proper way to create a route from a set of points.
> ST_MakeLine [1] can be used to aggregate a sequence of points into a line.
> [1] http://www.postgis.org/**documentation/manual-1.5/ST_**MakeLine.html<http://www.postgis.org/documentation/manual-1.5/ST_MakeLine.html>
> ______________________________**_________________
> postgis-users mailing list
> postgis-users at postgis.**refractions.net<postgis-users at postgis.refractions.net>
> http://postgis.refractions.**net/mailman/listinfo/postgis-**users<http://postgis.refractions.net/mailman/listinfo/postgis-users>
George R. C. Silva
Desenvolvimento em GIS
http://geoprocessamento.net
http://blog.geoprocessamento.net
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120328/68412b70/attachment.html>
