[postgis-users] POSTGIS 2.0 on WIn
Paragon Corporation lr at pcorp.us
Wed Mar 28 17:27:17 PDT 2012
We'll be releasing a 2.0.0rc1 soon probably in the next day or so.
Regarding why it's still not working
1) Did you run one of the batch scripts.
2) Can you verify you have the following files in your bin folder
a) libgdal-1.dll
b) libgeos_c-1.dll
c) libgeos-3-3-3dev.dll
d) libproj-0.dll (that I assume you already checked)
3) and you have postgis-2.0.dll and rtpostgis-2.0.dll in your lib folder
(Note these must go in the lib folder not the bin folder)
Let us know if it still doesn't work with those.  We haven't recently tested
on windows xp so there
might be some dependency that exists on windows 2008 and windows 7 (which
are the two platforms we've been testing mostly with) that we don't have in
place that is needed by xp.
We'll try that tomorrow on an xp box if you are still having issues.
Thanks,
Regina and Leo
http://www.postgis.us
> -----Original Message-----
> From: Piotr Pachól [mailto:piotrpachol at gmail.com]
> Sent: Wednesday, March 28, 2012 3:57 PM
> To: PostGIS Users Discussion
> Cc: Paragon Corporation
> Subject: Re: [postgis-users] POSTGIS 2.0 on WIn
> Hello,
> I tried all hints from this thread and that:
> http://postgis.refractions.net/pipermail/postgis-users/2012-Ma
rch/033111.html
> but it is still impossible to install PostGIS 2.0 on Windows XP.
> I also copied libproj-0.dll in bin folder - it didn't help.
> Do you have any other suggestion ?
> Piotr.
> W dniu 2012-03-27 04:26, Paragon Corporation pisze:
> > PROJSO  settings shouldn't be necessary anymore because
> libproj.dll is
> > not used.
> > I upgraded the install to use proj 4.8.0 so the dll is now
> > libproj-0.dll which is what gdal assumes by default.
> > It's possible I missed a dll and my tests systems already
> had them --
> > make sure you have libproj-0.dll in your bin folder.
> > I think if postgis is in use it won't be able to copy the
> dll so you
> > will probably need to shut down your service / restart and then run
> > the copy script.
> > Hope that helps,
> > Regina
> >> From: postgis-users-bounces at postgis.refractions.net
> >> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of
> >> Pierre Racine
> >> Sent: Monday, March 26, 2012 2:23 PM
> >>> Hi at all,
> >>> I wished test POSTGIS 2.0 on Win, so after installed on
> WinXP32   PostgreSQL 9.1.1,  and following instruction for
> postgis-pg91-binaries-2.0.
> >>> 0beta4w32 .... but I get the following error
> >>> "...C:\postgis-pg91-binaries-
> >>> 2.0.0beta4w32\postgis-pg91-binaries-
> >>> 2.0.0beta4w32>"C:\Programmi\PostgreSQL\9.1\bin\\psql"  -d
> "testpstg"
> >>> -c "CREATE EXTENSION postgis;" ERROR:  could not load
> library "C:/Programmi/PostgreSQL/9.1/lib/postgis-2.0.dll"
> >>> : unknown error 126 ".
> >>> Of course 1) postgis-2.0.dll is on the lib dir; 2) I stopped and
> >>> restared Postgres service; 3) I've tried also another
> installation dir for Postgers in order to prevent eventually
> "space in name" trouble, but...
> >>> I get the same problem
> >>> Any hints?
> >> Try setting the PROJSO to the path of libproj.dll
> >> Pierre
