[postgis-users] Z coordinate value changes with st_transform
Paul Ramsey
pramsey at opengeo.org
Fri Mar 30 12:30:14 PDT 2012
Turns out this is just because the definition of 23030 has been
updated to include a to_wgs84 parameter. You get the same behavior in
any version of proj. This is a feature, not a bug (our projection
information is now better). If you want the old behaviour, change the
proj4text of 23030 back to the 1.5 version.
For a future release you might file a ticket to allow users to apply
transforms x/y but to skip the z-coordinate.
P.
On Fri, Mar 30, 2012 at 10:27 AM, Paul Ramsey <pramsey at opengeo.org> wrote:
> Yeah, bad news, 2.0 is showing this behavour but not 1.5.
> http://trac.osgeo.org/postgis/ticket/1742
> P.
> On Fri, Mar 30, 2012 at 9:59 AM, Stefano Iacovella
> <stefano.iacovella at gmail.com> wrote:
>> Hi Jose
>> Im sure which version of PostGis are you using.
>> On my box, Postgis 1.5.3 with Proj 4.8 it seems to work without any
>> change to elevation:
>> template_postgis=# select
>> st_asewkt(st_transform(st_geomfromtext('POINT (700000 4500000 100)',
>> 23030), 4326));
>> WARNING: OGC WKT expected, EWKT provided - use GeomFromEWKT() for this
>> st_asewkt
>> SRID=4326;POINT(-0.635451186670006 40.6259397158234 100)
>> (1 row)
>> template_postgis=# select postgis_full_version();
>> POSTGIS="1.5.3" GEOS="3.3.2-CAPI-1.7.2" PROJ="Rel. 4.8.0, 6 March 2012" LIBXML=
>> "2.7.6" USE_STATS
>> (1 row)
>> Regards
>> Stefano
>> 2012/3/30 Jose Carlos Martinez <jomarlla at cgf.upv.es>:
>>> I didnt get nay answers from now.
>>> Someone can tell me why postgis is changing the z coordinate and how i can
>>> change this default behavior?
>>> Should I keep using proj4.7 instead of proj4.8?
>>> Before:
>>> pg20=# select st_astext(st_transform(st_geomfromtext('POINT (700000 4500000
>>> 100)', 23030), 4326));
>>> st_astext
>>> POINT Z (-0.63662073736203 40.6248036513963 100)
>>> Now:
>>> st_astext
>>> POINT Z (-0.63662073736203 40.6248036513963 168.35361468256)
>>> On 27/03/2012 21:56, Jose Carlos Martinez Llario wrote:
>>>> From proj4.8 changelog:
>>>> "Preliminary support has been added for vertical datums using the
>>>> +geoidgrids= directive. The geoidgrids are assumed to provide a
>>>> transformation from geoid elevations to ellipsoidal elevations and they are
>>>> discussed a bit in the VerticalDatums topic on the web site"
>>>> I dont like the st_transform method can change my z coordinates by default
>>>> though, dont know if it is because PostGIS is not ready still for proj4.8 or
>>>> because it is the proj4.8 default behaviour.
>>>> cheers,
>>>> Jose
>>>> On 27/03/2012 19:02, Jose Carlos Martinez wrote:
>>>>> Hi, dont know if this is the expected behavior, maybe its because I built
>>>>> postgis with proj 4.8 or because something has changed in spatial_ref_sys.
>>>>> Dont know at what time it happened (I missed it).
>>>>> Before:
>>>>> 4500000 100)', 23030), 4326));
>>>>> st_astext
>>>>> Now:
>>>>> st_astext
>>>>> Using ST_AsKml Its changing the Z coordinate too.
>>>>> Someone can confirm when this change happened in PostGIS?
>>>>> Regards,
>>>>> Jose
>>>>> _______________________________________________
>>>>> postgis-users mailing list
>>>>> postgis-users at postgis.refractions.net
>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
