[postgis-users] One server, several map projections
Mac Wind
macwind2 at gmail.com
Fri May 4 05:22:24 PDT 2012
Hi.
We are to install a brand new PostGIS Server from scratch, to store several
layers in several projects around the world.
Which is the best solution to cope with the different map projections?
- Several databases with the same map projection each one?
- One database in WGS84, and reprojecting data each time people use each
project?
Thank you very much!
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120504/e16a6b50/attachment.html>
