[postgis-users] Is it easy to convert a PostGIS Data Model into	an ArcGIS Server one?
    Stephen V. Mather
    svm at clevelandmetroparks.com
    Fri May  4 11:48:17 PDT 2012
AFAIK, PostGIS support in SDE is enterprise only, unless something has
changed.
I think Paul Ramsey made a FGDB reader (and writer?).  Not sure if that was
part of OGR or what.  Version 10 FGDBs and beyond though-- the 9.x FGDBs
have no api or published specs:
http://blog.cleverelephant.ca/2009/04/esri-formats-back-to-future.html
http://blog.cleverelephant.ca/2011/01/esri-fgdb-api-no-servers-need-apply.ht
ml
Oops-- with a search, Mr. Fee's google geospatial review foo shows up (even
in duckduckgo), ogr2ogr fgdb support:
http://spatiallyadjusted.com/2012/01/10/gdal-1-9-brings-esri-fgdb-and-google
-fusion-tables-support/
Best,
Steve
Stephen Mather
Geographic Information Systems (GIS) Manager
(216) 635-3243
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Nicklas
Avén
Sent: Friday, May 04, 2012 8:32 AM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] Is it easy to convert a PostGIS Data Model into
Can you not just register the POstGIS table in sde?
I think so, and then you will get all extra tables and overhead that sde
can offer.
/Nicklas
On Fri, 2012-05-04 at 14:04 +0200, Mac Wind wrote:
> Hi.
> Using the last version of postGIS, I've got dozens of layers.
> I wonder if it os possible (and easy) to convert/export this Data
> Model into a ArcGIS Server one (ArcSDE or FileGeoDataBase). Any
> experience/document is welcome.
> Does any interexchange format exist?
> Thank you very much.
> postgis-users mailing list
