[postgis-users] Very large WHERE clause?
Stephen Woodbridge woodbri at swoodbridge.com
Fri May 4 12:39:29 PDT 2012
On 5/4/2012 2:34 PM, DrYSG wrote:
> My users are presented with a list of checkbox for 4 different attributes
> (e.g. type of image, country, etc.)
> For type of image they can choose JPG, PNG, JP2000, etc. or turn off the
> check box.
> My naive implementation would have a WHERE clause with over 40 different
> tests (type='JPG' OR type='PNG' OR country='USA' ...)
> There has to be an more efficient way to do this (and gives better hints to
> the PLANNER).
> Suggestions?
I can't speak to the planner and I'm guessing that it has a lot to do
with what indexes are available and the statistics for any given column,
but there are some other syntax that you might consider:
could be represented as:
type in ('JPG','PNG')
type ~ '^(JPG|PNG)$'   -- case sensitive regex
type ~* '^(JPG|PNG)$'  -- case insensitive regex
You need to play with the syntax and EXPLAIN in your specific query for
example is you have a small number of options then:
is faster than
but if you have a very large number of options in your list then the
later is probably faster. An if you are using IN (...), I think it helps
if the list is in sorted order.
-Steve
