[postgis-users] PostGIS 1.5.4 Released
Paul Ramsey pramsey at opengeo.org
Sun May 6 03:41:20 PDT 2012
Download from:
  http://postgis.org/download/postgis-1.5.4.tar.gz
The news:
 This is a bug fix release, addressing issues that have been
 filed since the 1.5.3 release.
 - Bug Fixes
   - #547, ST_Contains memory problems (Sandro Santilli)
   - #621, Problem finding intersections with geography (Paul Ramsey)
   - #627, PostGIS/PostgreSQL process die on invalid geometry (Paul Ramsey)
   - #810, Increase accuracy of area calculation (Paul Ramsey)
   - #852, improve spatial predicates robustness (Sandro Santilli, Nicklas Avén)
   - #877, ST_Estimated_Extent returns NULL on empty tables (Sandro Santilli)
   - #1028, ST_AsSVG kills whole postgres server when fails (Paul Ramsey)
   - #1056, Fix boxes of arcs and circle stroking code (Paul Ramsey)
   - #1135, improve testsuite predictability (Andreas 'ads' Scherbaum)
   - #1146, images generator crashes (bronaugh)
   - #1170, North Pole intersection fails (Paul Ramsey)
   - #1179, ST_AsText crash with bad value (kjurka)
   - #1184, honour DESTDIR in documentation Makefile (Bryce L Nordgren)
   - #1227, server crash on invalid GML
   - #1252, SRID appearing in WKT (Paul Ramsey)
   - #1264, st_dwithin(g, g, 0) doesn't work (Paul Ramsey)
   - #1344, allow exporting tables with invalid geometries (Sandro Santilli)
   - #1389, wrong proj4text for SRID 31300 and 31370 (Paul Ramsey)
   - #1406, shp2pgsql crashes when loading into geography (Sandro Santilli)
   - #1595, fixed SRID redundancy in ST_Line_SubString (Sandro Santilli)
   - #1596, check SRID in UpdateGeometrySRID (Mike Toews, Sandro Santilli)
   - #1602, fix ST_Polygonize to retain Z (Sandro Santilli)
   - #1697, fix crash with EMPTY entries in GiST index (Paul Ramsey)
   - #1772, fix ST_Line_Locate_Point with collapsed input (Sandro Santilli)
   - #1799, Protect ST_Segmentize from max_length=0  (Sandro Santilli)
   - Alter parameter order in 900913 (Paul Ramsey)
   - Support builds with "gmake" (Greg Troxel)
