[postgis-users] ST_Within and GEOMETRYCOLLECTION
Martin Davis
mtnclimb at telus.net
Mon May 7 17:36:04 PDT 2012
The problem case is where a line does not lie completely in either
component, but does potentially lie in the union of the components. See
the attached image for a simple case. Essentially this requires
computing whether three line segments intersect in a point or which side
of an intersection point a segment lies, both of which requires
high-precision computation.
Trying to handle this would substantially complicate the current JTS
algorithm, which is one reason it wasn't done originally. Also,
there's robustness issues both with trying to compute the correct answer
with limited precision, and with overlaying polygons in general.
But it's definitely annoying that GCs are not handled by the
predicates. The intersects predicate as least could be fairly easily
extended to handle GCs.
On 5/7/2012 12:33 PM, Paul Ramsey wrote:
> On Mon, May 7, 2012 at 4:41 PM, Martin Davis<mtnclimb at telus.net> wrote:
>> It's because the underlying JTS/GEOS operation doesn't support
>> GeometryCollections. And this in turn is because of the details of the
>> implementation - in particular, handling the situation where two polygons
>> overlap. It would require computing the overlay of the polygons in order to
>> detect the within condition at the point of overlap.
> Why so? If you're in one component, does that end the test? The answer
> is 'true'.
> P.
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120507/86b07746/attachment.png>
