[postgis-users] building a polygon with variables
    Gold, Jack L  (US SSA)
    jack.gold at baesystems.com
    Tue May  8 07:26:48 PDT 2012
I'm not even sure how to express this properly, but I'll try.  I'm trying to build a query which will select positions within a specified polygon.  I have the query:
SELECT * FROM positions WHERE ST_Within(geometry(positions.location), ST_GeomFromText('POLYGON((l b, r b, r t, l t, l b))'::text, 4326));
I want to be able to replace l, b, r, and t with variable values in a plpgsql function like so:
$BODY$
DECLARE
                l integer;
                r integer;
                b integer;
                t integer;
BEGIN
SELECT pli_config.filter_left_longitude INTO l FROM pli_config;
SELECT pli_config.filter_right_longitude INTO r FROM pli_config;
SELECT pli_config.filter_bottom_latitude INTO b FROM pli_config;
SELECT pli_config.filter_top_latitude INTO t FROM pli_config;
  WHERE st_within(geometry(positions.location), st_geomfromtext('POLYGON((l b,r b,r t,l t,l b))'::text, 4326));
END;
$BODY$
The problem I have is I don't know the proper syntax to replace the variables in the single-quoted statement or even if it is possible.  Any ideas?
--Jack Gold
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120508/4a7a3f20/attachment.html>
