[postgis-users] building a polygon with variables
Gold, Jack L (US SSA)
jack.gold at baesystems.com
Tue May 8 07:36:28 PDT 2012
Thanks Stephen. That's exactly what I was looking for.
--Jack
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stephen Woodbridge
Sent: Tuesday, May 08, 2012 10:32 AM
To: postgis-users at postgis.refractions.net
Subject: Re: [postgis-users] building a polygon with variables
On 5/8/2012 10:26 AM, Gold, Jack L (US SSA) wrote:
> I'm not even sure how to express this properly, but I'll try. I'm
> trying to build a query which will select positions within a specified polygon.
> I have the query:
> SELECT * FROM positions WHERE ST_Within(geometry(positions.location),
> ST_GeomFromText('POLYGON((l b, r b, r t, l t, l b))'::text, 4326));
> I want to be able to replace l, b, r, and t with variable values in a
> plpgsql function like so:
> $BODY$
> DECLARE
> l integer;
> r integer;
> b integer;
> t integer;
> BEGIN
> SELECT pli_config.filter_left_longitude INTO l FROM pli_config;
> SELECT pli_config.filter_right_longitude INTO r FROM pli_config;
> SELECT pli_config.filter_bottom_latitude INTO b FROM pli_config;
> SELECT pli_config.filter_top_latitude INTO t FROM pli_config;
> WHERE st_within(geometry(positions.location),
> st_geomfromtext('POLYGON((l b,r b,r t,l t,l b))'::text, 4326));
'POLYGON(('||l||' '||b||','||r||' '||b||','....
> END;
> $BODY$
> The problem I have is I don't know the proper syntax to replace the
> variables in the single-quoted statement or even if it is possible.
> Any ideas?
> --Jack Gold
> postgis-users mailing list
