[postgis-users] st_offsetcurve
Francois Hugues
hugues.francois at irstea.fr
Wed May 9 04:02:31 PDT 2012
That's because has not been implemented by default in postgis : you have to run the script which simon gave you at the end of his article. This wil create the necessary functions
http://www.spatialdbadvisor.com/file_download/55/PostGIS_Parallel.sql
Hugues.
-----Message d'origine-----
De : postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] De la part de Pedro Costa
Envoyé : mercredi 9 mai 2012 12:28
À : PostGIS Users Discussion
Objet : Re: [postgis-users] st_offsetcurve
Hi Simon,
I had already seen its function. Congratulations.
But it returns me the following error:
ERROR: function st_parallel(geometry, integer, integer, integer) does
not exist
LINE 1: select (ST_Parallel(the_geom, 3, 0, 0)) as test
HINT: No function matches the given name and argument types. You might
need to add explicit type casts.
when i do this:
from tests
do you know the problem?
PS: I´m already install the function by your file
Em 09-05-2012 11:22, Simon Greener escreveu:
> You could try my ST_Parallel function that works with all geometry
> based versions of PostGIS.
> http://www.spatialdbadvisor.com/postgis_tips_tricks/205/st_parallel-for-postgis
> NOTE: Projected based math only.
> regards
> S
> On Wed, 09 May 2012 20:15:41 +1000, Pedro Costa
> <pedrocostaarma at sapo.pt> wrote:
>> Em 09-05-2012 10:46, Francois Hugues escreveu:
>>> If i'm not wrong, this function really dos not exists in postgis
>>> 1.5.3 and is avalaible since 2.0.
>> Thanks.
>> Anybody know a way of transform a polygon buffer in lines?
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
