[postgis-users] DE-9IM question
Martin Davis
mtnclimb at telus.net
Wed May 9 10:10:01 PDT 2012
No, we didn't prove exhaustiveness. But as you can see from the
documentation in the test cases we did try and formalize a system for
describing geometric configurations, with the idea that it might lead to
a way of enumerating all possible distinct situations. It would be
interesting to see this pushed through to a proof.
On 5/9/2012 9:32 AM, fork wrote:
> Martin Davis<mtnclimb<at> telus.net> writes:
>> Have a look at:
>> http://www.vividsolutions.com/jts/tests/index.html
>> This is a visual interface to the JTS Test Suite, which has a very
>> complete collection of DE-9IM cases.
> Interesting! Seems exhaustive to me. Two comments: Did you prove
> exhaustiveness - seems like there should be a way to make a combinatorial
> argument about how many possible Clementini matrices are possible (9^4 == 6561,
> less impossible combinations)? Also - it might be easier to do confirm
> exhaustiveness with simpler shapes, at least for part of the tests. Still,
> looks great, and comforts me that you are testing that hard.
>> As was mentioned, you can use the JTS TestBuilder to build and inspect
>> test cases. You can drag-and-drop Test Suite XML files onto the
>> TestBuilder, so it's easy to inspect the cases in the XML tests.
> That is cool!
>> I'm not sure if Wikipedia would appreciate being flooded with DE-9IM
>> test cases - it doesn't seem like quite the right place for it. The
>> Vivid site is a good reference as long as it stays up.
> I will continue to think about this. I probably don't have time to do fiddle
> with this in any systematic way, but a table with every possible matrix, a
> picture, and simple code to generate it might be pretty useful.
> postgis-users mailing list
> No virus found in this message.
> Checked by AVG - www.avg.com
> Version: 2012.0.1913 / Virus Database: 2425/4987 - Release Date: 05/09/12
