[postgis-users] RE :  return points where line intersects polys
    Francois Hugues
    hugues.francois at irstea.fr
    Thu May 10 11:34:53 PDT 2012
Hello,
I'm not totally sure of that but you could try this way:
1. Keep points from st_intersection
2. Extract points from lines using st_startpoint / endpoint (and add an attribut to identify which kind of point it is )
3. Dump your geometrycollection and re-do the two first steps to get just points
4. Make an union of all these results to have just one table
Hugues
-------- Message d'origine--------
De: postgis-users-bounces at postgis.refractions.net de la part de Puneet Kishor
Date: jeu. 10/05/2012 17:21
À: PostGIS Users Discussion
Objet : Re: [postgis-users] return points where line intersects polys
On May 7, 2012, at 3:44 PM, Stephen Woodbridge wrote:
> Hi Puneet,
> First if you intersect a line with a polygon you should expect to get back:
> 1. a line if it crosses the polygon or lies alont an edge of it
> 2. or a point if it touches a vertex
> 3. or a collection of these if there are multiple instances along the line
> The results are always returned in a GEOMETRYCOLLECTION.
> Also you should expect to get one result row for every row in  TABLE
> If you only want, results for rows the intersect then add a WHERE clause
> SELECT ST_AsText(ST_Intersection(ST_GeomFromText('LINESTRING(<p0>,<p2>)', 4326), the_geom))
>  FROM table
> WHERE ST_Intersects(ST_GeomFromText('LINESTRING(<p0>,<p2>)', 4326), the_geom);
Thanks... the above works well. But, now I am confused by a slightly different problem. How do I guarantee that the returned results are in the same order as the direction of the line? For example, given the line below (<p0> .. <pn>), how do I guarantee that I will get back "a, b" and not "b, a"?
Suggestions?
> -Steve
> On 5/7/2012 1:36 PM, Puneet Kishor wrote:
>> Given a line, I want to get the points at which it intersects a polygon dataset.
>>         |    a   |      b       |
>>     ====o========o==============o=======
>>     p0  |p1      |p2            |p3     pn
>> In the figure above, I want to get the following
>>     poly_id point1  point2
>>     a       p1      p2
>>     b       p2      p3
>>     FROM table;
>> But I back N 'GEOMETRYCOLLECTION EMPTY' where N = number of rows in the 'table'. From what I understand, that indicates "the geometries do not share any space (are disjoint)". But, I know that is not correct. So, my query is formulated incorrectly. What am I doing wrong?
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
Type: application/ms-tnef
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120510/e7ad4a6d/attachment.bin>
