[postgis-users] segmentation fault
Gold, Jack L (US SSA)
jack.gold at baesystems.com
Thu May 10 13:52:34 PDT 2012
I'm trying to rebuild my i386(RHEL5) database (PostGIS-2.0.1SVN) on x86_64 (CentOS). I've managed to build all of the libraries and I believe they are all installed correctly, but when I attempt to load postgis.sql, I get a seg-fault and the postmaster restarts wth:
...LANGUAGE 'plpgsql' IMMUTABLE STRICT;
ERROR: current transaction is aborted, commands ignored until end of transaction block
STATEMENT: CREATE OR REPLACE FUNCTION _ST_AsX3D(int4, geometry, int4, int4, text)
RETURNS TEXT
AS '$libdir/postgis-2.0','LWGEOM_asX3D'
LANGUAGE 'C' IMMUTABLE;
STATEMENT: CREATE OR REPLACE FUNCTION ST_AsX3D(geom geometry, maxdecimaldigits integer DEFAULT 15, options integer DEFAULT 0)
RETURNS TEXT
AS $$SELECT _ST_AsX3D(3,$1,$2,$3,'');$$
LANGUAGE 'sql' IMMUTABLE;
LOG: received fast shutdown request
LOG: aborting any active transactions
LOG: autovacuum launcher shutting down
LOG: shutting down
LOG: database system is shut down
LOG: database system was shut down at 2012-05-10 20:42:21 UTC
LOG: autovacuum launcher started
LOG: database system is ready to accept connections
LOG: server process (PID 8543) was terminated by signal 11: Segmentation fault
LOG: terminating any other active server processes
WARNING: terminating connection because of crash of another server process
DETAIL: The postmaster has commanded this server process to roll back the current transaction and exit, because another server process exited abnormally and possibly corrupted shared memory.
HINT: In a moment you should be able to reconnect to the database and repeat your command.
LOG: all server processes terminated; reinitializing
LOG: database system was interrupted; last known up at 2012-05-10 20:42:22 UTC
LOG: database system was not properly shut down; automatic recovery in progress
LOG: record with zero length at 0/2A9A0F0
LOG: redo is not required
LOG: server process (PID 8572) was terminated by signal 11: Segmentation fault
LOG: database system was interrupted; last known up at 2012-05-10 20:42:28 UTC
LOG: record with zero length at 0/2A9A148
LOG: server process (PID 8581) was terminated by signal 11: Segmentation fault
LOG: database system was interrupted; last known up at 2012-05-10 20:42:33 UTC
LOG: record with zero length at 0/2A9A1A0
I'm looking around for more detail, but I'm not seeing anything. Any ideas where I should look next?
--Jack Gold
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120510/d3a698c8/attachment.html>
