[postgis-users] Tools to change the encoding of the SHP/DBF files (from Latin1 to UTF-8)
Mac Wind
macwind2 at gmail.com
Thu May 10 14:39:28 PDT 2012
Hi Sandro. Thank you very much for your answer.
With that parameter (-W), am I changing the encoding of the DB or I am
merely indicating the encoding of the source?
Regards.
On Tue, May 8, 2012 at 3:13 PM, Sandro Santilli <strk at keybit.net> wrote:
> On Tue, May 08, 2012 at 02:56:28PM +0200, Mac Wind wrote:
> > Hi.
> > Using PostGIS 1.5 on Windows, I get this error message when trying to
> > import a SHP:
> > Unable to convert data value to UTF-8 (iconv reports "Invalid argument").
> > Current encoding is "UTF-8". Try "LATIN1" (Western European), or one of
> the
> > values described at
> > http://www.postgresql.org/docs/current/static/multibyte.html.
> > Really my data are in Latin1 encoding, but I don't want to change the
> > encoding of the DataBase into Latin1, but change the encoding of the SHP
> > (in fact, of the DBF) into UTF-8.
> > Which tool could I use to do this? Thank you very much.
> You don't have to change DB encoding, just tell the loader that your
> data is in Latin1:
> $ shp2pgsql -W Latin1 ...
> --strk;
> ,------o-.
> | __/ | Delivering high quality PostGIS 2.0 !
> | / 2.0 | http://strk.keybit.net - http://vizzuality.com
> `-o------'
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120510/a99c98d3/attachment.html>
