[postgis-users] PostGIS Raster with Map Server
Pierre Racine
Pierre.Racine at sbf.ulaval.ca
Sun May 13 04:40:15 PDT 2012
If http://www.gdal.org/gdal_translate.html does not work fine there is not much to do with MapServer. So give it a try first.
Pierre
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-
> bounces at postgis.refractions.net] On Behalf Of abhishek bansal
> Sent: Sunday, May 13, 2012 7:30 AM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] PostGIS Raster with Map Server
> no i dont know about them.. but anyhow now i am able to get that raster layer.
> (I think there was some permission issue in database tables). But now I am
> having artifacts in my raster image. I can see orthogonal black lines in my output
> image. Are they because of tiling ..I am not able to get that.. please help !
> Thank You
> On Sun, May 13, 2012 at 4:53 PM, Pierre Racine <Pierre.Racine at sbf.ulaval.ca>
> wrote:
> Did you try to do gdalinfo and/or gdal_translate with the same
> parameters?
> Pierre
> users-
> > Sent: Saturday, May 12, 2012 1:19 AM
> > And url I am using for mapserver is
> > http://localhost/cgi-
> bin/mapserv.exe?map=/ms4w/Apache/htdocs/raster_wmsServerPostGIS.map&
> SERVICE=WMS&VERSION=1.1.1&REQUEST=GetMap&LAYERS=rasterLayer,point
> s1,waterways&STYLES=&SRS=EPSG:4326&BBOX=68.820812,8.082365,96.07060
> > 2,34.585531&WIDTH=800&HEIGHT=600&FORMAT=image/png
> > I am able to see waterways and points1 whicha re my vector layers
> but not
> > rasterlayer.
> > I am also not able to visualize this rasterlaer in QGIS.
> > I am stuck at this point.
> > On Sat, May 12, 2012 at 10:11 AM, abhishek bansal
> <discover.ab at gmail.com>
> > wrote:
> > Thanks for your reply
> > sorry that was a typo in the mail... that didn't help also!!
> > On Sat, May 12, 2012 at 3:51 AM, <pcreso at pcreso.com> wrote:
> > It looks like you are missing a quote in your data statement after
> "'asdf " and my
> > have an extra one at the end?
> > That might help...
> > Brent Wood
> > --- On Sat, 5/12/12, abhishek bansal <discover.ab at gmail.com> wrote:
> > From: abhishek bansal <discover.ab at gmail.com>
> > Subject: [postgis-users] PostGIS Raster with Map Server
> > To: postgis-users at postgis.refractions.net
> > Date: Saturday, May 12, 2012, 2:27 AM
> > hello all,
> > I am very new to all this Geo-spatial world. I am using map server
> to
> > display my maps in browser. I am also using Postgres and PostGIS
> raster to store
> > my tiff images in database. now I need to configure mapserver map
> file to
> > display this tiff file which is stored in database. I googled a lot and
> found this
> > technique which is not working for me i.e. my raster image does not
> show up
> > while using GetMap.
> > I created my raster using following command
> > raster2pgsql -s 4326 -I -C -M my.tif -F -t 100x100 public.asdf >
> elev.sql
> > than I imported this sql file into my PostGIS database using
> postgres PG
> > Admin 3.
> > My map file layer config is as follows:
> > LAYER
> > METADATA
> > "wms_title" "rasterlayer" ##required
> > END
> > NAME rasterlayer
> > CONNECTIONTYPE postgis
> > DATA "PG:host=localhost port:5432 dbname='postgis'
> user='postgres'
> > password='something' schema='public' table='asdf mode='2''"
> > PROCESSING "NODATA=0"
> > PROCESSING "SCALE=AUTO"
> > STATUS ON
> > TYPE RASTER
> > PROCESSING "BANDS=1,2,3"
> > OFFSITE 71 74 65
> > END
> > I found this in postGIS documentation.
> > this return me a empty image in browser.
> > Plz help !!
> > Thanks & Regards,
> > Abhishek Bansal
> > http://abhishekbansal.miyuri.com
> > Jaypee Institute of Information Technology, Noida
> > -----Inline Attachment Follows-----
> > postgis-users mailing list
> <http://mc/compose?to=postgis-
> > users at postgis.refractions.net>
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
> > Thanks & Regards,
> > Abhishek Bansal
> > Thanks & Regards,
> > Abhishek Bansal
> Thanks & Regards,
> Abhishek Bansal
