[postgis-users] Correct or wrong raster image loading
Bborie Park
bkpark at ucdavis.edu
Mon May 14 12:45:35 PDT 2012
Giannis,
If your tile size is the same as the raster size, you're only going to
get one tile (and one row). Now if you were specify a tile size smaller
than the raster size (such as 30x31), you would have 117 tiles (and rows).
I wouldn't be concerned about not seeing the whole blob in pgAdmin.
pgAdmin usually does that for data that is particularly large.
-bborie
On 05/14/2012 12:07 PM, Giannis Giakoumidakis wrote:
> Thanks for the anwser.
> My raster is 390x279, so I use -t 390x279. I get no errors. I didn't understand from your asnwer, the rows in the table should have been more than 1 that it is now or it is correct like that?
> The .sql I get before I use psql is this, in Notepad++:
> BEGIN;
> CREATE TABLE "public"."cc00h00m15s" ("rid" serial PRIMARY KEY,"rast" raster);
> INSERT INTO "public"."cc00h00m15s" ("rast") VALUES ('0100000400DDC80B44AA83173FF2C80B44AA8317BF1986D9154421394032D1D677B4AE414000000000000000000000000000000000E6100000860117010400828282828282828282828282.......')::raster;
> ANALYZE "public"."cc00h00m15s";
> SELECT AddRasterConstraints('public','cc00h00m15s','rast',TRUE,TRUE,TRUE,TRUE,TRUE,TRUE,FALSE,TRUE,TRUE,TRUE,TRUE,TRUE);
> END;
> I don't know why in the sql editor of pgAdmin, the: VALUES ('0100000400DDC80B44AA83173FF2C80B44AA8317BF1986D9154421394032D1D677B4AE41400....') are missing.
> ________________________________
> From: Bborie Park <bkpark at ucdavis.edu>
> To: postgis-users at postgis.refractions.net
> Sent: Monday, May 14, 2012 8:07 PM
> Subject: Re: [postgis-users] Correct or wrong raster image loading
> What are the dimensions (width/height) of your raster? I just tested
> your raster2pgsql command string...
> raster2pgsql -s 4236 -I -C -M *.tif -F -t 100x100 testtable
> And it has no issues. The generated table will only have 2 or 3 columns
> (3 since you specified -F). Each raster column will have one entry in
> the raster_columns view.
> You may wan to check the SQL generated from raster2pgsql instead of
> piping directly to psql. I'm guessing something went wrong in the
> raster loading process. Without additional information (error messages,
> if any), we really can't say what is wrong.
> -bborie
> On 05/14/2012 09:01 AM, Giannis Giakoumidakis wrote:
>> I'm not sure if my loading of raster images is correct.
>> I use "raster2pgsql -s 4236 -I -C -M *.tif -F -t 100x100 public.demelevation | psql -d gisdb" from the manual. What I get is a table that has only 3 columns (rid, rast, filename) and 1 row only (I thought -t would create many rows). Also, 12 constraints. Finally, 1 row in the "raster_columns" view, which contains all the details of the loaded raster.
>> The difference with a loaded shapefile is that this table has 55.000 rows that contains all the vector data details.
>> So I have a major problem when I connect to the database through QGIS. There I can load and display normally a shapefile from the database (it appeas with "MULTIPOLYGON" type), but all the tables which contains rasters appear with "no geometry" type and can't be displayed in QGIS.
>> Can anyone tell me where is my fault, in the QGIS or in the first loading of the raster images in the database? Thanks.
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
