[postgis-users] PostGIS KNN best practices
Alexandre Neto
senhor.neto at gmail.com
Wed May 16 04:35:06 PDT 2012
I have been around that question to.
http://gis.stackexchange.com/questions/24456/nearest-neighbor-problem-in-postgis-2-0-using-gist-index-function
You have to do it in two steps, like is explained in the operator
page<http://postgis.refractions.net/docs/geometry_distance_centroid.html>.
One faster step to reduce the candidates (by using <-> or <#>) and second
one to get the real distances with ST_Distance.
The problem in finding the KNN for each row in a table is the fact that the
gist index <-> operator only works if one of the geometries is constant.
The workaround would be to create a SQL function to apply to each of the
rows using table.the_geom as a parameter.
Something like this:
CREATE OR REPLACE FUNCTION _enn2 (geometry) RETURNS double precision AS $$
WITH index_query as
(SELECT ST_Distance($1,f.the_geom) as dist
FROM "grelha5m" As f
ORDER BY $1 <#> g1.the_geom limit 1000)
SELECT dist
FROM index_query
ORDER BY dist;
$$ LANGUAGE SQL;
and I call it like this:
Select c.gid as gid, _enn2(c.the_geom) as enn
>From cosn1 as c
Order by c.gid
In this case the function returned the smallest distance, but you can
choose any other column.
Hope it helps
Alexandre Neto
On Tue, May 15, 2012 at 5:37 PM, Stephen V. Mather <
svm at clevelandmetroparks.com> wrote:
> Hi All,****
> Pretty excited by the new operators <-> and <#>, but a bit
> confused as to how to use them in a query. The two examples from P. Ramsey
> back in late 2011 (
> http://blog.opengeo.org/2011/09/28/indexed-nearest-neighbour-search-in-postgis/) included doing a KNN on a single point to a cloud of points, i.e.
> SELECT name, gid****
> FROM geonames****
> ORDER BY geom <-> st_setsrid(st_makepoint(-90,40),4326)****
> LIMIT 10;****
> or doing KNN on non-point different geometries, where the first neighbor
> by <-> or <#> might not be truly the first i.e.****
> with index_query as (****
> select****
> st_distance(geom, 'SRID=3005;POINT(1011102 450541)') as distance,****
> parcel_id, address****
> from parcels****
> order by geom <#> 'SRID=3005;POINT(1011102 450541)' limit 100****
> select * from index_query order by distance limit 10;****
> So, how would one grab the first nearest neighbor for all points in a
> dataset? This is how I used to do it:****
> CREATE TABLE n2180_560_height AS ****
> SELECT x, y, height FROM ****
> (SELECT DISTINCT ON(veg.gid) veg.gid as gid, ground.gid as gid_ground,
> veg.x as x, veg.y as y, ground.z as z, veg.z - ground.z as height,
> veg.the_geom as geometry, veg.class as class****
> FROM (SELECT * FROM n2180_560 WHERE class = 5) As veg, (SELECT * FROM
> n2180_560 WHERE class = 2) As ground****
> WHERE veg.class = 5 AND veg.gid <> ground.gid AND ST_DWithin(veg.the_geom,
> ground.the_geom, 10)****
> ORDER BY veg.gid, ST_Distance(veg.the_geom,ground.the_geom)) AS vegpoints;
> ST_DWithin prevents a full cross join, but is a sloppy way to do this, as
> it requires a priori knowledge of the end cases. I’m hoping there’s a
> subquery or some such magic that would allow me to use the distance
> operator to a similar end… .****
> Thanks,****
> Best,****
> Steve****
> **[image: http://www.clemetparks.com/images/esig/cmp-ms-90x122.png]**Stephen
> Mather
> Geographic Information Systems (GIS) Manager
> (216) 635-3243****
> clevelandmetroparks.com <http://www.clemetparks.com/>****
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120516/b3a2039f/attachment.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120516/b3a2039f/attachment.png>
