[postgis-users] RE : st_offsetcurve
Pedro Costa
pedrocostaarma at sapo.pt
Thu May 17 01:42:33 PDT 2012
Thanks Hugues...
In this time the select return the street number, my_single_geom and
my_union_geom.
The my_union_geom are the two parallels right?
I tried to see the result in qgis, adding a new column (the_geom) equal
to the column my_union_geom, and adding a new entry inthe table
geometry_columns. But I can not see the result, qgis does not recognize
as a geometry column.
What would have to do to see the result?
Thanks
Em 15-05-2012 06:56, Francois Hugues escreveu:
> Ok, the error comes from the select : try using select a.n_street, my_union_geom, ST_Parallel(the_geom,-3.0,0,0) my_single_geom
> I forgot to add the table reference "a."
> I think I made another mistake using the over method. It would rather be something like that :
> select n_street, st_union(ST_Parallel(the_geom,3.0,0,0)) over(partition by n_street) my_union_geom,
> ST_Parallel(the_geom,-3.0,0,0)) my_single_geom
> from streets
> Firts time I read too fast.... this time I wrote too fast !
> Hugues.
> -------- Message d'origine--------
> De: postgis-users-bounces at postgis.refractions.net de la part de Pedro Costa
> Date: lun. 14/05/2012 17:36
> À: PostGIS Users Discussion
> Objet : Re: [postgis-users] st_offsetcurve
> Thank you Francois but still error.
> Using this:
> With my_union as (
> select n_street, st_union (ST_Parallel(the_geom,3.0,0,0)) my_union_geom
> from streets
> group by n_street)
> select n_street, my_union_geom, ST_Parallel(the_geom,-3.0,0,0) my_single_geom
> from my_union a
> join streets b on a.n_street = b.n_street
> give me this error:
> column reference "n_street" is ambiguous
> I put the table name but give me another error:
> invalid reference to FROM-clause entry for table "my_union"
> Em 11-05-2012 11:01, Francois Hugues escreveu:
>> Hi,
>> This error is normal. You can not use a group by clause with an aggregate function and keep all of single records from your original database. Which one will you choose to keep for each unique n-street value ?
>> To do that you can use two different tricks (but your table will have as many lines as you have unique couple n_street/the_geom):
>> Using "with" with a join
>> With my_union as (
>> from streets
>> group by n_street)
>> from my_union a
>> or using an over function (not totally sure of this particular request but the window function can certainly help you in this case)
>> select n_street, st_union (ST_Parallel(the_geom,3.0,0,0)) ,
>> ST_Parallel(the_geom,-3.0,0,0))over(partition by n_street)
>> from streets
>> group by n_street
>> Hugues.
>> -----Message d'origine-----
>> De : postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] De la part de Pedro Costa
>> Envoyé : vendredi 11 mai 2012 10:30
>> À : PostGIS Users Discussion
>> Ups, sorry...
>> The whole sql:
>> create table test4 as
>> (select n_street, st_union (ST_Parallel(the_geom,3.0,0,0)) ,
>> (ST_Parallel(the_geom,-3.0,0,0))
>> from streets
>> group by n_street)
>> Em 11-05-2012 00:03, Simon Greener escreveu:
>>> Pedro,
>>>> greate. The funcion works.
>>>> I'm doing something like that:
>>>> but give me error:
>>>> column "streetss.the_geom" must appear in the GROUP BY clause or be used
>>>> in an aggregate function
>>>> anybody know the problem?
>>> Not without the whole SQL statement.
>>> S
>>>> thanks
>>>> Em 10-05-2012 04:40, Simon Greener escreveu:
>>>>> Folks,
>>>>> Sorry about that. The file:
>>>>> http://www.spatialdbadvisor.com/file_download/55/PostGIS_Parallel.sql
>>>>> Did not contain all the required types and functions. One needed also
>>>>> to access the types and functions for my ST_GetVector function.
>>>>> I have now included all the required types and related functions in
>>>>> the above script and replaced it on my site.
>>>>> I have changed a bit in the code as it didn't handle some situations
>>>>> as I expected. Hopefully my test cases give good coverage.
>>>>> My tests, conducted on PostgreSQL 9.1 and PostGIS 2.0 on Windows 7 64
>>>>> Bit all work as this example shows:
>>>>> With geometries As (
>>>>> select ST_GeomFromText('LINESTRING(1 1,1 10)') as geom,
>>>>> 10.0 as offset,2 as roundFactor,0 as curved
>>>>> union all select ST_GeomFromText('LINESTRING(0 0,1 1,1 2)') as geom,
>>>>> 0.5 as offset,2 as roundFactor,
>>>>> generate_series(0,1,1) as curved
>>>>> union all select ST_GeomFromText('LINESTRING(0.0 0.0, 45.0 45.0, 90.0
>>>>> 0.0, 135.0 45.0, 180.0 0.0, 180.0 -45.0, 45.0 -45.0, 0.0 0.0)') as
>>>>> geom,
>>>>> union all select ST_GeomFromText('MULTILINESTRING((0 0,1 1,1 2),(2 3,3
>>>>> 2,5 4))') as geom,
>>>>> 0.5 as offsetRight,2 as roundFactor,
>>>>> select ST_AsText(g.geom) as origGeom, g.offset,g.curved,
>>>>> ST_AsText(ST_Parallel(g.geom,g.offset,g.roundFactor,g.curved))
>>>>> as geomWKTLeft,
>>>>> ST_AsText(ST_Parallel(g.geom,0.0-g.offset,g.roundFactor,g.curved)) as
>>>>> geomWKTRight
>>>>> from geometries as g;
>>>>> "LINESTRING(1 1,1 10)";10.0;0;"LINESTRING(11 1,11 10)";"LINESTRING(-9
>>>>> 1,-9 10)"
>>>>> "LINESTRING(0 0,1 1,1 2)";0.5;0;"LINESTRING(0.35 -0.35,1.5 0.79,1.5
>>>>> 2)";"LINESTRING(-0.35 0.35,0.5 1.21,0.5 2)"
>>>>> "LINESTRING(0 0,1 1,1 2)";0.5;1;"COMPOUNDCURVE((0.35 -0.35,1.35
>>>>> 0.65),CIRCULARSTRING(1.35 0.65,1.46 0.81,1.5 1),(1.5 1,1.5
>>>>> 2))";"LINESTRING(-0.35 0.35,0.5 1.21,0.5 2)"
>>>>> "LINESTRING(0 0,45 45,90 0,135 45,180 0,180 -45,45 -45,0
>>>>> 0)";10.0;0;"LINESTRING(7.07 -7.07,45 30.86,90 -14.14,135 30.86,170
>>>>> -4.14,170 -35,49.14 -35,7.07 7.07)";"LINESTRING(-7.07 7.07,45 59.14,90
>>>>> 14.14,135 59.14,190 4.14,190 -55,40.86 -55,-7.07 -7.07)"
>>>>> 0)";10.0;1;"COMPOUNDCURVE((7.07 -7.07,45 30.86,82.93
>>>>> -7.07),CIRCULARSTRING(82.93 -7.07,90 -10,97.07 -7.07),(97.07
>>>>> -7.07,134.71 31.15,170 -4.14,170 -35,49.14 -35,7.07
>>>>> 7.07))";"COMPOUNDCURVE((-7.07 7.07,37.93 52.07),CIRCULARSTRING(37.93
>>>>> 52.07,45 55,52.07 52.07),(52.07 52.07,89.71 13.85,127.93
>>>>> 52.07),CIRCULARSTRING(127.93 52.07,135 55,142.07 52.07),(142.07
>>>>> 52.07,187.07 7.07),CIRCULARSTRING(187.07 7.07,189.16 4.01,190 0),(190
>>>>> 0,190 -45),CIRCULARSTRING(190 -45,187.13 -52.01,180 -55),(180 -55,45
>>>>> -55),CIRCULARSTRING(45 -55,41.27 -54.28,37.93 -52.07),(37.93
>>>>> -52.07,-7.07 -7.07))"
>>>>> "MULTILINESTRING((0 0,1 1,1 2),(2 3,3 2,5
>>>>> 4))";0.5;0;"MULTILINESTRING((1.65 2.65,3 1.29,5.35
>>>>> 3.65))";"MULTILINESTRING((2.35 3.35,3 2.71,4.65 4.35))"
>>>>> "MULTILINESTRING((0 0,1 1,1 2),(2 3,3 2,5 4))";0.5;1;"MULTICURVE((1.65
>>>>> 2.65,2.65 1.65),CIRCULARSTRING(2.65 1.65,3 1.5,3.35 1.65),(3.35
>>>>> 1.65,5.35 3.65))";"MULTILINESTRING((2.35 3.35,3 2.71,4.65 4.35))"
>>>>> Sorry for any inconvenience.
>>>>> The file is available for download via the link above.
>>>>> regards
>>>>> Simon
>>>>> On Wed, 09 May 2012 23:27:04 +1000, Pedro Costa
>>>>> <pedrocostaarma at sapo.pt> wrote:
>>>>>> No problem Hugues.
>>>>>> Give me the same error:
>>>>>> ERROR: function st_parallel(geometry, numeric, numeric, integer) does
>>>>>> not exist
>>>>>> LINE 1: select ST_Parallel(the_geom, 3.0, 0.0, 0) as test from tests
>>>>>> Em 09-05-2012 13:48, Francois Hugues escreveu:
>>>>>>> Sorry, I read your message too fast and forgot the PS.
>>>>>>> Maybe you could try something like :
>>>>>>> Hugues.
>>>>>>> Pedro Costa
>>>>>>> Envoyé : mercredi 9 mai 2012 13:06
>>>>>>> Em 09-05-2012 11:28, Pedro Costa escreveu:
>>>>>>>> PS: I´m already install the function by your file
>>>>>>> I'm already do that...
>>>>>>> _______________________________________________
>>>>>>> postgis-users mailing list
>>>>>>> postgis-users at postgis.refractions.net
>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120517/db086361/attachment.html>
