[postgis-users] optimize query
Bborie Park bkpark at ucdavis.edu
Tue May 22 14:35:08 PDT 2012
Jack,
You'll want to check to make sure that you have a spatial index on
dted_elevations.  Beyond that, the following suggestions usually help...
1. What is your tile size?  Smaller is always faster both in terms of
spatial granularity and data retrieval time.  I generally have all my
tiles (regardless of type of raster) sized between 25x25 and 50x50.
2. How large is your table?  This would be total # of rows and the total
"on-disk" size.  If your table fits in memory, things will be faster
over successive calls.
I just wrote something similar last week where you're driving a pin
through an elevation raster.  My SQL template is...
WITH f AS (
	SELECT ST_Transform(
		ST_SetSRID(
			ST_MakePoint(
				%s,
				%s
		, 4326)
	, 4269) AS geom
SELECT
	ST_Value(t.tile, f.geom)
FROM ned.%s t
CROSS JOIN f
WHERE ST_Intersects(
	t.tile,
	f.geom
	AND ST_Value(t.tile, f.geom) IS NOT NULL
I'm using USGS NED 10m where each source raster is kept in its own table
with each tile being 53x53.  I could have used partitioned tables but I
got lazy.  On disk, each table is between 300 - 500 MB (including TOAST
and indices).  For the query above with a user-defined longitude and
latitude, the resultset is returned in ~0.2 seconds.
-bborie
On 05/22/2012 02:16 PM, Gold, Jack L (US SSA) wrote:
> I'm finding a search query we wrote is running really slow.  Any ideas on how to optimize this better?  Or is this the best I can do?
> SELECT ST_Value(rast, ST_Transform(ST_SetSRID(ST_Point(66.12, 37.32), 4326),ST_SRID(rast))) FROM dted_elevations WHERE ST_Intersects(rast, ST_Transform(ST_SetSRID(ST_Point(66.12, 37.32), 4326), ST_SRID(rast)));
> --Jack Gold
> postgis-users mailing list
Bborie Park
Programmer
Center for Vectorborne Diseases
UC Davis
530-752-8380
