[postgis-users] tiger_geocoder import error
Paragon Corporation
lr at pcorp.us
Wed May 23 12:32:32 PDT 2012
My mistake that is the right name. It the 5 digit zcta. so looks like it
imported fine for you and that's not the issue.
Will if you can give me an example point, I can check it out.
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On
> Behalf Of Jeff Rossi
> Sent: Wednesday, May 23, 2012 3:26 PM
> To: postgis-users at postgis.refractions.net
> Subject: Re: [postgis-users] tiger_geocoder import error
> For some reason the table is called fl_zcta5, and it has 983 rows.
> I am running the script to import tiger 2011 into a separate database.
> http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp
4997634p4997738.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
