[postgis-users] tiger_geocoder import error
Jeff Rossi
rossi.jeff at gmail.com
Wed May 23 17:05:01 PDT 2012
The 2011 data imported correctly and results look pretty good.
On Wed, May 23, 2012 at 3:53 PM, Jeff Rossi [via PostGIS] <
ml-node+s17n4997746h37 at n6.nabble.com> wrote:
> The geocoder seems to only report one point per city if that helps with
> your diagnosis.
> If you reply to this email, your message will be added to the discussion
> below:
> http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634p4997746.html
> To unsubscribe from tiger_geocoder import error, click here<http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=4997634&code=cm9zc2kuamVmZkBnbWFpbC5jb218NDk5NzYzNHwtNjQ5NjEzMjk4>
> NAML<http://postgis.17.n6.nabble.com/template/NamlServlet.jtp?macro=macro_viewer&id=instant_html%21nabble%3Aemail.naml&base=nabble.naml.namespaces.BasicNamespace-nabble.view.web.template.NabbleNamespace-nabble.view.web.template.NodeNamespace&breadcrumbs=notify_subscribers%21nabble%3Aemail.naml-instant_emails%21nabble%3Aemail.naml-send_instant_email%21nabble%3Aemail.naml>
Regards
Jeff Rossi
Intouch MVC
1506 Tuscaloosa Ave
Holly Hill, FL 32117
(386) 226-8979
View this message in context: http://postgis.17.n6.nabble.com/tiger-geocoder-import-error-tp4997634p4997756.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120523/55070d15/attachment.html>
