[postgis-users] Ubuntu and Postgresql9.1.3-2
Jeff Meyer
jeff at gwhat.org
Thu May 24 08:24:46 PDT 2012
The instructions at http://trac.osgeo.org/postgis/wiki/UsersWikiPostGIS20Ubuntu1204 should address all of these issues.
Be sure to read the "The bad news:"about using the existing packages.
The later section explains how to build PostGIS from source, so you shouldn't hit the bug in the current package.
I'm not sure when 9.1.3-2 dropped, but if it hasn't been in the last 2-3 weeks, then, yes the instructions at that link work with Ubuntu 12.04.
>________________________________
> From: Sandro Santilli <strk at keybit.net>
>To: PostGIS Users Discussion <postgis-users at postgis.refractions.net>
>Sent: Thursday, May 24, 2012 7:37 AM
>Subject: Re: [postgis-users] Ubuntu and Postgresql9.1.3-2
>On Thu, May 24, 2012 at 07:27:38AM -0700, Brian H Wilson wrote:
>> On 05/24/2012 05:13 AM, José María Amuedo wrote:
>> >I understand all steps I have to following to get the installation, but:
>> >Do we know if someone installed PostGIS 2 with PostgreSQL 9.1.3-2 in
>> >Ubuntu 12_04 LTS????
>> >Thanks
>> It happens my new desktop has a recent Ubuntu 12.04 install (AWESOME
>> new computer! :-), and I don't usually run PostGIS on it (I keep it
>> on a server in the other room) so I removed the postgres client
>> previously installed on the desktop like this
>> sudo apt-get -f remove postgresql-client postgresql-client-common
>> Next I tried these instructions on the computer I am sitting at,
>> from the first link I sent yesterday
>> sudo apt-get install python-software-properties
>> sudo apt-add-repository ppa:sharpie/for-science
>> sudo apt-get update
>> sudo apt-get install postgresql-9.1-postgis
>> Now I have
>> psql --version
>> psql (PostgreSQL) 9.1.3
>> contains support for command-line editing
>> I also have two versions of GDAL installed now, for what it's worth,
>> postgres at laysan:~$ /usr/bin/gdalinfo --version
>> GDAL 1.7.3, released 2010/11/10
>> postgres at laysan:~$ /usr/local/bin/gdalinfo --version
>> GDAL 2.0dev, released 2011/12/29
>> I have found having different versions of things can be a problem,
>> hence I usually just install things from sources to get all the
>> features and most up tp date gdal possible. But for now I press
>> on...
>> In the past I have always used the procedure outlined on my wiki to
>> add PostGIS to PostgreSQL. Therefore creating a geodatabase meant
>> using a template. Today I try the command you suggested.
>> This is where I have a problem -- using EXTENSION
>> postgres at laysan:~$ createdb test
>> postgres at laysan:~$ psql test
>> psql (9.1.3)
>> Type "help" for help.
>> test=# CREATE EXTENSION postgis;
>> ERROR: function st_asgml(integer, geography, integer, integer,
>> text, text) does not exist
>> test=#
>> Seems like I got further than you José but still encountered a problem.
>It's a recent bug. Someone packaged a broken revision of PostGIS.
>Current trunk is fine, if you mail the package maintainer he'll know
>what to do.
>--strk;
> ,------o-.
> | __/ | Delivering high quality PostGIS 2.0 !
> | / 2.0 | http://strk.keybit.net - http://vizzuality.com
> `-o------'
>_______________________________________________
>postgis-users mailing list
>http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120524/4803174b/attachment.html>
