[postgis-users] Difference between ST_Union and ST_Collect
Sandro Santilli strk at keybit.net
Fri May 25 03:30:46 PDT 2012
On Fri, May 25, 2012 at 08:21:25PM +1000, Luca Morandini wrote:
> On 05/25/2012 07:26 PM, Sandro Santilli wrote:
> >On Fri, May 25, 2012 at 01:52:45PM +1000, Luca Morandini wrote:
> >>after seeing some polygons disappear during the generalization
> >>process, I found out that ST_Union and ST_Collect are different
> >>beasts when dealing with intersecting lines.
> >Yes, ST_Collect simply puts things togheter. ST_Union computes the
> >point set union. Isn't the manual page clear about that ?
> That is clear, what I did not suspect was the different behaviour
> when there are "loops" in the collection of lines given as
> argument... well, it may be ST_BuildArea that has a different
> behaviour when the argument is a collection of linestrings or a
> single geometry.
BuildArea is not an aggregate so won't "internally" collect the inputs.
I'm not sure this solves your problem.
--strk;
  ,------o-.
  |   __/  |    Delivering high quality PostGIS 2.0 !
  |  / 2.0 |    http://strk.keybit.net - http://vizzuality.com
  `-o------'
