[postgis-users] Nearest neighbor in 3D
Bartosz Bekier bartosz.bekier at gmail.com
Sat May 26 07:00:54 PDT 2012
2012/5/26 Paul Ramsey <pramsey at opengeo.org>
> Using ST_3DDistance will work and give you the right answer, but it
> will not be index assisted. The KNN operator <-> is only implemented
> against the 2D index currently.
Ok, I see, thanks for confirming that. I'll try to use ST_3Ddwithin() to
limit the number of results, it seems to use the index.
Regards,
Bartosz
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20120526/e6a24096/attachment.html>
